I was having a huge problem with that. I cleaned them and readjusted them. 10X better. Then when the new door was put up they were cleaned and adjusted by the installers and we *knock on wood* haven’t had a problem since.Speaking of garage doors does anybody have any tips for having problems with the door closing when the sun is at a certain angle and it shines directly into the sensor eyes? I tried reversing them and it seemed to help but it was a fluke. My only other thought is some type of shroud around the sensor but I’d rather not have to fabricate something like that in case there’s a different solution
If I didn’t have a 2 year old I’d be down
Here’s a quick sketch of my idea. The white is a totally not-to-scale representation of my garage opening from above with the arrow pointing outside. The red represents my current placement of the sensors. They are actually set back a few inches in real life. The yellow is the angle of the sun at exactly 6:30am around this time of year, exactly when I need to go to work and the thing won’t close. the green is my idea. I think it’ll cut the angle off enough to help
Exactly. Mine passed, but the door wouldn’t stop and go back up if it hit something. That was just a sensitivity issue. Still showed up on the report.That get mentioned in the inspection report? Mine got dinged for being a few inches too high.
Ohh yeah it was on the report. least of our concerns on the house when we bought it though. actually see that beam that the lenses are mounted to in that picture I posted? the previous owner used this 150 year old wood from a barn when they had the addition built. neat!That get mentioned in the inspection report? Mine got dinged for being a few inches too high.
Lord Tin Foilhat is that you?!?!Here’s a quick sketch of my idea. The white is a totally not-to-scale representation of my garage opening from above with the arrow pointing outside. The red represents my current placement of the sensors. They are actually set back a few inches in real life. The yellow is the angle of the sun at exactly 6:30am around this time of year, exactly when I need to go to work and the thing won’t close. the green is my idea. I think it’ll cut the angle off enough to help
Tint the lens.Here’s a quick sketch of my idea. The white is a totally not-to-scale representation of my garage opening from above with the arrow pointing outside. The red represents my current placement of the sensors. They are actually set back a few inches in real life. The yellow is the angle of the sun at exactly 6:30am around this time of year, exactly when I need to go to work and the thing won’t close. the green is my idea. I think it’ll cut the angle off enough to help
Best I could come up with was some LA’s totally awesome degreaser from the dollar store. Dilute that shit because it strong AF. $10 garden sprayer from Home Depot. Spray on the degreaser water solution. Quick wipe with a rag and hose off and remaining. Gutters looks 95% better. Do not let the degreaser dry on anything. It will leave a white residue and it very hard to get off unless you spray more degreaser on and scrub, then hose off very well.What’s the best way to get the black streaks off white gutters and facia? Something lazy like spray on and walk away?
Any idea what all of the screw holes were from? They have exterior shelves or something?Started prepping house for paint. Filled in the million screw holes from last homeowner. Sanded fill holes and scrapped flaking paint/sanded fascia.
Also sealed under the soffit, had 1/8" - 1/4" gaps in some spots.
North wall ready for paint. Just have to remove the window well covers. Going to hopefully get the wall painted tomorrow and another side prepped.
ScrewsAny idea what all of the screw holes were from? They have exterior shelves or something?
Some were nails embeeded too deep when they put on the siding leaving holes, so I filled those in.Any idea what all of the screw holes were from? They have exterior shelves or something?
Ahh. Those items on the wall would have made great archery targets, with the wall being the backstop ?Some were nails embeeded too deep when they put on the siding leaving holes, so I filled those in.
Some they had like 3-4 screws for each thing they hung and they had the cable running along that way previously that has been pulled and rerouted to a single hole.
Here is a pic from when they were here. You can see the cable along the bottom and stuff mounted on the walls.
