🔧 BUILD BOTTLEFEDS 96 cobra build
Ok, time to make the build thread so here goes
I bought this car about 4 years ago it was supposed to be "just a driver" while I finished a notchback that I was building,well the notch was sold to lineup on here and this build just keeps going now.
The car has had a bunch of different combos on it first was motor,then nitrous,then blower, then,blower and nitrous, currently it has a ysi and two kits on it lol
The details
Motor :
Stock b headed 120k mile motor yikes!
Short runner intake done by Nasvt
Chromed intake hat
mmr Imrc delete plates
Accufab throttle body
Bbk full length headers
Trans:
Stock t45
Spec aluminum flywheel
Spec stage 2 clutch
Aluminum driveshaft
B&m ripper shifter
Rearend:
Housing straightened and tubes welded by strange
Che rear axle brace
Upr axle brace
31 spline strange axles
T/a diff cover
4:30 gear
Detroit locker
Suspension:
Upr tubular k member -pile of shit
Upr tubular a arms- also garage
12" 250lb coil overs on front
Strange adjustable struts
Maximum motorsports caster camber plates
Eibach springs rear
Strange adjustable shocks
Upr adjustable upper control arms
Upr solid lowers
Poly Rearend bushings
Supercharger kit:
vortech ysi headunit
10% inovators west overdrive
5" thick intercooler
Tial bov
Anderson power pipe
interior:
Black on black 04 cobra seats
Full array of autometer gauges
Flip out screen headunit
Car is being built to just be a nice cruiser that I can have the ac on in traffic without an issue if I want, next upgrades will be moving battery to trunk and cleaning up more of the wiring under the hood, then doing the entire fuel system to run e85 this year
Reactions: SaturdaysGS
BOTTLEFED
2,769
5,713
Posting for BOTTLEFED BOTTLEFED. His seat delete came out great!
Mook Mook, thanks for posting this, havent had much time to update, but car is back in my garage now so lots of work happening. this part is sort of done, still need to paint the cage and make it look pretty, and several other projects with trans etc. .More to come!!
BOTTLEFED
2,769
5,713
I finally got to test fit these "Brembo" brakes, everything fits the way i need it to with both sets of wheels, Before anyone questions the "Cadillac" caliper, this is a kit that someone came up with that bolts right on, so for a few hundred you can have brembo brakes, I am also upgrading the rear calipers to a 43mm to keep the brake bias correct. So now there will be no issues slowing this junk down at the track.
The Beast
28,543
33,160
South beach
Go Go
AView attachment 163556 View attachment 163557
Got a few things done on this pile, Cage painted, harnesses in, shifter installed, switches for lockup/overdrive/trans cooler all wired in, Still tons of stuff to be done.
Nice work Joe it’s come a long way from seeing it at Augustinos on rte 64 with a 4.6 5 speed and zex nitrous and peeling roof.
118,948
Leonardo Dicaprio Reaction GIF by Once Upon A Time In Hollywood
Reactions: BOTTLEFED
BOTTLEFED
2,769
5,713
Who’s kit? I’ve been wanting to do the caddy brakes for years now but could never get a straight answer from any fucktard online.
The calipers i bought myself, from rock auto/amazon they were like$110ea, then there's the insert/rotor spacer kit from s&s engineering. Ill find the part numbers and text you.
Reactions: Milhouse
