• As many of you are aware, TCG experienced downtime at the beginning of May. Unfortunately, we had to restore the site from a 2023 backup. If you created a new account after August 2023, it has been lost and will need to be recreated. If you're having trouble logging in, please use the "Contact Us" form and I’ll address it right away. - Mook
🧰 BUILD Boostie’s 1987 Notchback
I will hop on board in the build section here as I have been a member of TCG and big follower of sloppy on FB over the years.
Quick run down of my turd that I built completely out of my garage.
Basic SS2 don’t bs me style build for the engine on E85
Shiny Borg turbo
Th400 with PTC converter
Holley Terminator setup with 7” dash
Bunch of Low Dollar sensors and SEP injectors
On board air setup for boost control/airing tires
Lots of fancy un-needed suspension
Just got the car running recently but looking forward to this coming year. So far I’ve been doing the tuning on my own but may throw it on the dyno eventually
Quick clip when I was first setting up the simple stage
Boostie
2,465
2,611
Stressful weekend, updated the ECU to V6 build 300 & the firmware on the 3.5 & 7” dashes. Started the car with the dominator and everything so far seems kosher
Also one of my biggest pet peeves has been how the hids in the stock housings just scatter light. Took them apart and retrofitted some bixenon projectors in
Boostie
2,465
2,611
Went from wanting to light the car on fire to having a super productive weekend.
1: the projectors apparently are too hot for the cheap American (China) muscle lenses and one distorted. Ordered new ones and said f it for now
2: my jegs electric water pump decided it wanted to start leaking. They don’t sell replacement motors so $700 later we have a meizure that does not leak and is serviceable
3: I’ve always hated having to have help when getting out of the water box. I like to pull a couple inches out of the water before doing my burnout. Half the time people aren’t paying attention. A crafty mounted reverse cam fixed that
5: finally got around to installing my driveshaft speed sensor.
June is going to come quick but hoping to get the cage cert done asap and get my nhra license passes done
Boostie
2,465
2,611
That camera setup is awesome. I was thinking about putting a cheap aftermarket backup camera on my car also because I also don't like needing help in the burnout box or with staging.
$10 on amazon and has built in white LED lights which work great in the dark. I did not want infared so this was perfect. For the price I have zero complaints. https://amzn.to/42be11b
01bluesnake
D Mark Performance
Jul 8, 2009
2,802
4,991
43
See if you can record while making a pass, looks like a great shot to see the shock compression/extension and tire as well.
Boostie
2,465
2,611
You and I think alike! I can set a go pro to record the screen in car but have already started looking into what kind of 12v AV input recorders are out there. Id like to put shock travel sensors on the car so that data would probably be more helpful down the road. I am a huge fan of data so the more I can collect the better
Reactions: 01bluesnake
Boostie
2,465
2,611
Got my cage cert finally done. Legal to 8.50
@PJx5x made me a badass trailer hitch. I owe him my life
I
Took the car to gld and had a less than great experience. Had some tube related stuff to work through and ended up blowing a coupler off that I wasn’t able to fix at the track. Will be heading back soon
The car as of now waiting on a bead roller
Boostie
2,465
2,611
At least it's only a pretty minor set back. Better than doing something horrid to the engine.
That's what I keep telling myself. I am still nervous with the new engine as everything is fresh and sounds different but first oil change looked good and it saw some boost yesterday issue free. Through problems you rebuild stronger and better!
