As most know I have a 1967 Camaro with a driveline swap. Currently it runs a gen 3 LM7 SBE, stock L99 heads, a Capizzi cam grind, ARP hardware and a Melling oil pump. The rest of the combo includes a FIS billet wheel 85/96 turbo, Shearer air=air intercooler and all of the necessary parts to support this boost combo.
I have no idea how many miles are on the engine parts lol. My long term plan has been to build a forged LC9 and to run aftermarket heads.
I've been working with the following industry players for an all-forged boost engine that is gettting built this year:
GM LC9 engine block, bored .005 over
TFS-30619991 TFS 220 Cylinder Heads
SUM-180LS362224x Pro LS 3.622 crank
SUM-LS6125927 Pro LS 6.125 H-Beam rods with ARP 2000’s
SUM-2999273785-7 Pistons
ARP-234-4317 Head studs
ARP-234-5608 Main Studs
AAF-ALL87024 Cylinder head dowels
NAL-12575329 Chevy Performance O.E. 5.3L bore replacement head gaskets
TFS-21407500 pushrods
SUM-HTLSKIT2 Delphi LS7 lifter and tray kit
NAL-12561513 Long Crank Key
SUM-161000 Short Crank Key
CLE-SH2125S Cam Bearings
MEL-10295 Melling Oil pump
SUM-G1585 LS Engine Hardware Kit / Plugs Dumbbell/ Side Bolts
SUM-G2627 Cam Change Gasket kt
SUM-G2621 Rear Cover with Main Seal
SUM-150106 Cam Retainer Plate
ARP-134-1003 Cam Bolts
ARP 234-2503 Crank Bolt
TFS-30675540 Timing Chain damper
ARP-200-8683 Windage Tray Nuts
ARP-671-1002 Oil pump Bolts
ICB-551432 Timing Cover bolts
SUM ___ LS engine diaper
I plan to reuse my Holley 302-2 oil pan and Holley High Ram intake.
The block is over with Graham Jones @ FastTimes. He determined that we are good with a .005 over bore which was going to effect the piston selection.
I kicked back and forth staying stock crank but the one in the builder block was not usable so that was not even an option.
Again this is a parts list in progress, I'll note when it's been edited.
- Summit Racing (www.summitracing.com)
- FastTimes Motorworks (www.fasttimesmotorworks.com)
- Jon Capizzi Racing (www.capizziautomotive.com)
