Bonneville brake hoses
Mattstrike
Random Crazy Custom Car guy
Feb 13, 2014
542
1,139
I need to get some extended front brake hoses, prefer to upgrade to stainless, as well get rear stainless hoses.
Fronts need to be about 20.5" long, have a 10mm banjo and an M10x1.0 bubble flare fitting.
Rears are 12-3/8" and have the M10x1.0 fitting on both ends.
I couldn't find a vendor that has these pre-made, don't have the tools/supplies to try making my own. Where can I get something made (for a not-insane price)?
Mattstrike
Feb 13, 2014
542
1,139
That's odd, when I go to ZZPs site from my home computer I get the old interface and none of the dropdown menus worked so I thought they were no longer offering extended lines.
why so much longer in the front.
3" longer because I'm setting up a 13.4" Z51 rotor and needed to re-clock the F-body caliper so the bolt heads clear the knuckle.
32,638
16,096
as long as its the std teflon liner id bet it'd be alright...but keep in mind the non stainless braids will be less abrasion resistant. not to mention i do not think it'd be DOT legal
just keep in mind that the fluid inside the line will be at high pressure and high temperature with radiant heat coming off the caliper/rotor well over the 300 odd degree's of the brake fluid.
probably be fine....might not
