Bolting Up My KB
FuelSlut
FK RED STAR
Ok getting ready to bolt up the KB as soon as I get the supporting mods. So Exactly what do I need
60# injectors
Kenne Bell Boost a pump? And what amp should it be?
And MAFia mass air
And Dyno Tune
Will I need anything else? Im not going to push over 20psi ever so I dont think the fuel rails are necessary, but for those that have upgraded to a bigger blower your help is appreciated. :biggthump
Bullitt-1469-
I got 60 lb injecotrs and an sct ba 2400 for sale you will need these :biggthump
Bob_Kurgan
Flyin_Hawaiin
i stock 60lbs inj, harnesses, and Mafias at all times.. email if i can help!
thanks
FuelSlut
FuelSlut
FK RED STAR
Are the injectors used or new, and how much for both?
Jack1
I have a MAF Extender for sale in my sig.
does the same exact thing as a MAFia
and to answer your question 40AMP BAP
Dana
Bluesmobile
You should consider a high flow intake system also.
JLT has some nice setups.
No, you won't need, nor do you want, new fuel rails.
FuelSlut
FuelSlut
FK RED STAR
I have the K&N Set up, I think it should be good enough.
