Build Bob’s 85 k5 blazer CUCV build, it’s got boost, it’s got 1 ton axles and zero creature comforts!
Thread
When I first got it
Colorado turbo time
1 tons & bigger turbo
Trans swap
Lets summarize the shit diesel.
It started with a text from a friend saying come get it for cheap. This is what I ended up with.
Started painting. The desert sand color was in rough shape. When it would get wet you could see the original OD green bleed through.
I've got a thing for green and thought it should go back to its original color since the carc tan was in poor shape.
The suspension rode rough as shit due to it being completely sagged in front. I ordered a set of tuff country HD springs (still softer spring rate than other companies) and a set of 2" blocks for the rear. Turns out the 2" lift, lifted the truck nearly 4".
I hated how small the stock 31x10.5" tires looked after the lift so I ordered some 33" general grabbers since I didn't want to push my luck with the shit 3.08 gears.
Interior got bedlined along with some storage added.
Then I moved to Denver and this went from a DD to something I wanted to hit trails with (there are hundreds of miles of legal trails in the area). The biggest problem was actually getting to trail heads because they all started at at least 8,000ft and got over 12,000ft easily. So a change had to come.
Got an awesome deal on some 6.5 diesel shit. Had to piece together other stuff and mod some things to get it to fit.
Turbo install in my shitty tight 1 car garage:
My crossover
Gauges
All finished:
Got some other stuff put on like extended brake lines and sway bar disconnects:
Hidden winch install:
60" Hi lift just in case:
Bob Kazamakis
I’m the f-ing lizard king
Posts
88,003
Sweet build. It looks like the 208c case bolts up to the nv4500? Im assuming the nv4500 is a chevy one originally
Yea 208 bolts right to it, as long as it’s a 32 spline that was behind a th400 or sm465. Need an adapter for a 205 plus people suggest a second cross member for it since they’re heavy as shit
Bob Kazamakis
Posts
88,003
Thats good to know! I ASSumed some type of AA adapter would be needed to keep it passenger side drop. Super handy
I did end up with an advance bell housing. You can mod an sm465 bell to work with a 93-95 nv4509. 96+ uses a different bolt pattern but has an internal slave that clears everything from my understanding.
Bob Kazamakis
Posts
88,003
My front brakes brought my track width out like 1/2” on each side. I was already running a 1/2” spacer out back to try and make up some difference in width. Now I’m off I think an inch total each side with the spacers. :fu:
Bob Kazamakis
Posts
88,003
Pulled tail shaft housing to swap it to the 2wd one and pulled the pto covers to reseal them. Still waiting on my conversion control arms. Hoping I can just axle over the rear for now to get it lower as I’d like to keep the 14 bolt.
Also popped the 5th gear nut off and applied a liberal amount of red thread locker. I torqued it to as tight as I fucking could get it so hopefully that’s enough.
Bob Kazamakis
Posts
88,003
Just kidding. Got my shit transferred over from old t case to new and then hung on the trans. At that point I realized something was wrong. I didn’t account for the stock mount when I measured the original adapter so it needs to be an inch higher. I ordered a big chunk of 2x2x12 .25” wall square steel and I’ll just put it between the mount and the trans when it shows up. I jammed a 1” block under the mount for now.
Chopped up the t case shifter to fit back in there. Not sure about what I can do for the bezel since the indicator starts right at the corner that’ll interfere. I’ll probably just get a boot for each and no bezel needed
