https://youtu.be/6164R_SL8ao
Highlights:
3.0L Twin Power Turbo inline 6 cylinder (S58) engine
473 HP / 442 LB-FT (Standard model)
503 HP (Competition model)
0-60 in 4.1 seconds (standard model)
0-60 in 4.0 seconds (Competition model)
155 MPH top speed (electronically limited)
174 MPH top speed (for standard model if optioned with M Driver's Package)
177 MPH top speed (for Competition model if optioned with M Driver's Package)
Production begins April 2019
Engine / Exhaust
473 HP (standard model) and 503 HP (Competition model) from 6250-7200 RPM
442 LB-FT torque from 2600-5600 RPM (standard model) and 2600-5950 RPM (Competition model)
Forged crankshaft
7200 RPM redline
Closed deck design
Wire-arc sprayed-on iron coating for cylinder walls
3D printing technology cuts weight of cylinder heads
Two mono-scroll turbochargers
350 bar maximum fuel injection pressure
Valvetronic and Double-VANOS variable camshaft timing
100 mm exhaust tailpipes
M Sport exhaust system standard for Competition models
Transmission / Cooling
8 Speed M Steptronic transmission with three shift modes
M xDrive intelligent all-wheel-drive system
Active M Differential (allows rear lockup between 0-100%)
Cooling
One large central radiator and two smaller radiators sides
Engine oil cooler and a separate transmission oil cooler
Lightweight oil sump has two separate chambers and an integrated suction channel
Chassis / Suspension
Strut brace in the engine compartment that links the shock towers
Carbon fiber strut brace will be available as an option beginning August 2019
A-strut in front section near the firewall, with two further struts increasing stiffness between the shock towers and the front of the car
Large rear brace and model- specific rear axle control arms
Double-joint spring strut front suspension and Five-link rear suspension feature model- specific bushings
Custom-made swivel bearings, torque arms and wishbones in front suspension
Increased front wheel camber
Model-specific components and custom bushings in rear suspension
Stiff camber arm
M-specific rubber mounts for all control arms and the rear suspension subframe
Model-specific anti-roll bars (larger bars on the Competition models)
Adaptive M Suspension controls damping forces for each wheel individually
Steering
M Servotronic system combines speed-sensitive power assistance and a variable ratio
Steering response can be varied by pushing a button to select one of three settings
Brakes / Wheels / Tires
Four- piston fixed front calipers and single-piston floating rear calipers at the rear
Drilled, inner-vented brake discs measure 395 millimeters (15.6 inches) in diameter at the front and 370 millimeters (14.6 inches) at the rear
Cast- iron brake discs with aluminum hubs
M light-alloy wheels in V-spoke design and mixed size high-performance tires (non-runflat)
20-inch wheels in polished Orbit Grey finish with 255/45 ZR20 tires at the front and 265/45 ZR20 tires at the rear (standard model)
21-inch wheels with a polished Jet Black finish with 255/40 ZR21 tires at the front and 265/40 ZR21 at the rear (Competition model)
Exterior / Colors
Seven exterior colors, including new Toronto Red metallic and M-exclusive Donington Grey metallic.
Competition Model
Standard equipment on the Competition models includes:
21-inch M light-alloy wheels in polished Black
M Sport exhaust system with tailpipes in Black Chrome
Specially designed door sill plates and model badging
M Carbon Exterior Package
Optional M Carbon exterior package (expected to be available from August 2019), will feature design elements in carbon fiber- reinforced plastic (CFRP) for the front air intakes, the air blades in the front apron, the rear diffuser and the exterior mirror caps
On the BMW X4 M and BMW X4 M Competition, these elements will be joined by a CFRP rear spoiler
Interior
Standard: heated sports seats in Vernasca leather with embossed M logo
Optional: M Sport seats in extended Merino leather (standard on Competition model)
Vernasca leather upholstery in a choice of Black or Oyster with an embossed M logo at the top of the backrests,
Interior trim strips in Aluminum carbon structure.
Competition X3M and X4M come standard with M Sport seats in extended Merino leather upholstery that can be specified in either Black or bi-color choices in Sakhir Orange/Black or Adelaide Grey (optionally available for standard models)
Optional extras include BMW Individual extended Merino leather upholstery in Ivory White and Tartufo (only in conjunction with the M Sport seats) and Carbon Fiber interior trim strips.
Extended Merino leather upholstery in the new Midrand Beige/Black color choice with Alcantara applications is available exclusively for the BMW X3 M Competition and BMW X4 M Competition models
Standard and Optional Equipment
Standard:
Adaptive Full LED lights
Harman Kardon surround sound audio system
SiriusXM Satellite radio with 1 year subscription
Navigation with Apple Car Play compatibility
Comfort Access keyless entry
Full array of advanced driver assist systems including Active Guard, Active Protection Active Driving Assistant and Frontal Collision Warning with City collision mitigation.
Optional packages include:
Driving Assistance Plus Package with Active Cruise Control with Stop & Go and Extended Collision Mitigation
Executive Package with heated steering wheel, heated front and rear seats, parking assistant plus, head-up display, wireless charging, WiFi hotspot and gesture control.
more info:
https://x3.xbimmers.com/forums/showthread.php?t=1582854
Highlights:
Engine / Exhaust
Forged crankshaft
7200 RPM redline
Closed deck design
Cooling
Stiff camber arm
Steering
Exterior / Colors
Competition Model
Interior
Standard:
more info:
