blown head gasket, need help!
grey03svt
Active member
driver side head gasket appears to be blown... i dont know what the hell im doing when it come to cams and timing chains. i do ALL the work on all of my vehicles, but a head gasket on a DOHC car makes me frightened...
any tips guys?
teamstorm02
that kinda stuff on these mod motors makes me feel the same way!... good luck man!
Bob_Kurgan
Flyin_Hawaiin
are you sure its a blown head gasket?? That's nearly impossible to do on a 4valve.
grey03svt
grey03svt
Active member
in the well below the lower intake i have coolant pooled up. at first before i pulled the old blower off, i thought my LDC cooling mod was leaking. but with everything off, i can see that it is not...
i also have a small amount of oil on a part of the head gasket that sticks out a bit.
and checking out my coolant tank, i have small black in there.
i hope its not a head gasket, but what/where would that stuff come from?
i have pics on my phone ill try posting them in a bit
grey03svt
grey03svt
Active member
the pic with the red circle is the oil pooled on the head gasket.
FuelSlut
FK RED STAR
pm dun4791. His name is Lyle. Or Dana they do work together and do a great job. Very good pricing. They can help you for sure, they work out of Beecher. GL.
grey03svt
grey03svt
Active member
so from the pics, does it look like it may be a head gasket? i have the service manual on cd, and from the looks of the head removal/install, its a complete bitch...
zimmer0924
Master Debater
Tell me about it. I had to remove my drivers side head about two weeks ago. I marked the hell out the timing gear and chain. Good luck.
Fast99Snake
track rat
do a compression test, that will tell you for sure if it's a hg
you've gotta pull the motor on the dohcs to do the head gasket iirc
Bob_Kurgan
Flyin_Hawaiin
not true... the only real way is to do a leakdown test... compression test wont show small leakage into water passages.
grey03svt
grey03svt
Active member
Well I have the new blower on the car now. I'm just waiting on a belt and a new BF pulley. I couldn't do the exhaust gas in the coolant test... And I tried to pressurize the cooling system, but the fitting kept popping off the coolant tank, then the hand pump broke! $180 to rent that kit from advanced... I guess I'm going to have to test after I just installed a brand new blower......
zimmer0924
Master Debater
Since there is coolant right below the lower intake, could it be possible that it's leaking coolant from where the supercharger and the lower IC meet? Maybe a hole in the lower IC some where?
ShelbyGuy
Turgid Member
I have the tools for doing stock ford cams
Heads lifting off the gaskets on these cars is more common than people care to admit, apparently. I know of a handful of cars, and at least one isnt even a drag racer.
grey03svt
grey03svt
Active member
my coolant level in my IC tank was never low, but the main tank for the cooling system would always be low after i drive it.
Mystic Terminator
Guilty :-o
Been there - Done that... :damnit:
