Blown engine update
indyridgerunner
Active member
ok I got the intake lid and valve covers off. all 4 chains look to be ok although the passenger side exhaust cam is locked up tight. I pulled the plugs, and they are undamaged and there isnt any damage or debris visible through the holes. thats as far as i have got so far. will pull the cam out after a few hours of sleep, and see what I can see. opinions? we'll see who is right?
Zack
4 Doors 4 Life
NW Indiana
My friend who is a ford tech sees this every once in a while. Its always an oiling issue due to a blockage in that cam cap.
Sounds like you got lucky...you will need a new head, cam, both heads rebuilt, head gaskets/bolts etc etc.
If you do the work yourself it will probably cost you about $1000
musclemerc
Agreed, find a nice used set of heads (or rebuild yours) and drop in a set of 98 Cobra intake cams while your at it. You can get the exhaust cams on the cheap
RacerX
If you need an MM exhaust cam, let me know. I have DS and PS exhaust cams in excellent shape. You pay shipphing and you can have it. Give me the Ford part number off it when you pull it if you're interested.
indyridgerunner
Active member
i found the problem and ended up calling the previous owners exhusband. long story short. driver side short chain broke. he replaced it, but it appears to have 2 bent intake valves in #8 cylinder. I wont know anything further until i dig a little deeper.
indyridgerunner
Active member
cam lobes appear ok, but found some marks on the casting part of the cams probably from when the chain broke. would love to find some of the 96-98 cobra cams. i dont really want to spend $1200 on cams yet. have to prioritize at this point in the build, or should i say possible rebuild if i have damaged pistons.
RacerX
Cool. Good luck and if you do happen to need any stock MM cams in good condition, just ask!
indyridgerunner
Active member
Just a little update. As some of you know my F350 was stolen a couple months ago which kind of put a hault to my build, but that ordeal is finally coming to an end so I feel comfortable with spending a little of my nest egg again. I am pleased to say My MM will be paying Mr. Zack a visit for some much needed TLC. I'm looking forward to the meeting The Man. The Myth. The Legend known as Zack. :)
Zack
4 Doors 4 Life
NW Indiana
^^^LOL I think you will be more impressed with my basement than me.
raresvt
This is exactly what happened to me!! Only I wasn't so lucky I broke the secondary chain on the driver side, and ruined the head. New bearings, heads and valvetrain along with crower stage 3 cams I was in it for close to 4k
guspech750
Guspech Superdriller
North Aurora
Oh yeah. Another interesting thread in the works. Looking forward to reading about this saga.
Sent from my iPhone
Eaton Swap + 4.10's = Wreeeeeeeeeedom!!
indyridgerunner
Active member
I'm hoping there isn't too much of a saga = $$$ lol I'm getting excited. Thats for sure.
guspech750
North Aurora
The shop is expecting your heads next Monday.
If they look good, as well as the shortblock, this is a 1,2,3 job for me.
What was Doms job? A 1,2,3 - 100?
Sent from my iPhone
indyridgerunner
Active member
I'm hoping all thats wrong with the heads are a couple of bent valves or dropped seats or both on #8 cylinder. It's hard to see the face of the cylinder head with the video probe. All I could tell was both exhaust valves are open. I couldn't tell why. The good news is that I couldn't see any evidence that anything touched the piston. It even left a mark in the carbon on top of the piston when I pushed the video probe in too far. I'm keeping my fingers crossed for the best possible scenerio. No matter what Zack finds when he gets it apart. I know it will be right when I get it back. :)
4DoorBlackTop
Sent from my iPhone
Mine was no 3 day job by a long shot. Even if we had all parts and moneys from the beginning. Even then I was expecting it to take as long as it did. No doubts in Zack at all, I just knew this was a major project.
Plus finding all the other things need replacing.
Zack
4 Doors 4 Life
NW Indiana
^^^i would have been done in 3 weeks had I known everything and had everything.
