Bleeding brakes but nothing coming out of one corner..
tinfoilhat
Riding the Hubble
Car is a 2006 Cobalt SS/SC.
When I was bleeding the brakes, the passenger rear wouldn't pull any brake fluid through when I loosened the bleed valve. I was using a Motive Brake Bleeder @ 15psi. Worked perfectly for the 3 other corners.
What could cause a caliper to not bleed?
greasy
I Haz New Teknologee
The Litter Box
Did you start with the caliper furthest from the master cylinder, usually the passenger rear?
tinfoilhat
Riding the Hubble
Its actually different with the cobalts since they have a cross system. I went LR, RF, RR, LF. All the others worked. RR nothing came out. No visible leaks or fluid on the ground anywhere.
Eagle
Nemo me impune lacessit
Woodsticks, IL
Uhm, my totally unprofessional feedback would be, close all the other bleeders, make sure the system is full with fluid and capped...
Then have someone slowly press the brake with that bleeder open until that caliper produced fluid (closing it prior to each time they release the pedal of course).
Once it produces fluid, resume using the bleeder.
:dunno:
Bruce Jibboo
yup ^^ and possibly just wrap it up manually like the good old days :rofl:
sickmint79
I Drink Your Milkshake
grayslake
looks like it can get clogged with dirt/rust/whatever maybe? interested in what you ultimately find out.
tinfoilhat
Riding the Hubble
Problem solved. Bleeder screw was clogged. Cleaned it out and good to go.
