I have a good shop vac. I'm going to replace the plastic liner with a pane of sacrificial glass too. I just need to find a place that will cut me a few pieces for cheap.The light only does so much. You need a more powerful vacuum to clear the unit.
We throw a clear vinyl cover on ours and replace it frequently.I have a good shop vac. I'm going to replace the plastic liner with a pane of sacrificial glass too. I just need to find a place that will cut me a few pieces for cheap.
I am going to look into this now. Maybe I need just one piece of glass to take up the thickness and then the vinyl can be sacrificed. Do you just buy the ones specifically made for cabinets?We throw a clear vinyl cover on ours and replace it frequently.
The corners that didn't fit before only get worse when the legs are bolted on. The shims are not thick enough. Whoda thunk?View attachment 138277
I still have no idea wtf that trim ring? Gasket? Flange? Is supposed to do except cause a massive leak! Even if you didn't caulk anything, I think omitting it is a much better solution. It doesn't align with any of the holes anyway.
Woohoo! It's starting to look like something.
This is what the plastic window under the glass lamp oka like right out of the friggin package. No thank you.
I'm probably not going to put this on wheels like a lot of folks do. I just don't see the point. However, it does need to be raised. Will have to hunch over just to get my hands in the holes and that's not going to fly for more than a couple minutes.
Yup, directly on the glassPerhaps I don't understand how destructive the media is or why the HF cabinet is designed the way it is.
Mine comes with a nice glass pane for the top, a plastic sheet to go under that (the one I held in the picture), AND a few replaceable sticky liners. You cannot see through the plastic window. I don't understand the purpose of the foggy plastic window when you already have liners.
So Im not sure how bad the liners are yet because I haven't opened them. Do you just put yours directly on the glass?
Jeez, that vibe motor sounds nice. This pick-up method is considered an absolute must by all the videos and threads I've seen. The provided siphon tube is complete trash. This may still not be ideal, but I assume it's much better than what the $200 initial investment. ?I'd be curious to see how that pick up works. What collects at the bottom is usually the junk and media that has more or less become unusable, at least thats what I see on mine. I do have a vibratory motor that runs whenever the cabinet is on, to keep blast media where I need it. Not sure if that helps bring the bad stuff down range by the flap door.
I'm leaning toward just cutting some acrylic and sticking liners to it. Even with the provided parts they aren't going to seal, because the factory put the foam strip on the wrong side. I will get some foam weather stripping from Lowes to fix that. Do you just use the lower window as the sacrificial piece? Do you not use the sticky liners?For the glass and the plastic piece, I just went to the local hardware store and bought glass close to the same size and then cut the rest to fit. Think it was the right height but a few inches longer. They carry real clear plastic at the same spot at least in Home Depot and Menards. You need either 2 pieces of glass or the glass/plastic to get the right thickness or else the window area won't seal. The cabinet isn't very big and if you get enough pressure going the media bounces off the glass and etches it very quickly.
I tried multiple different options for the pickup tube including a TPtools version and a modded version I found on some forum plus a few others. The problem is the media collecting at the bottom stops the siphon effect or creates a pulse because there isn't enough airflow. I did away with all that crap, I just used a piece of 1" electrical conduit with a piece of hose and dropped it strait through the grate to the bottom, if you leave it rest on top of the media it shouldn't clog or pulse and if it does you just pull up on the tube for a second to clear it.
Those LED lights look bright but just like the glass the media will etch the housing so be mindful of that.
Not sure how tall you are but I welded large Castors on the bottom legs to raise the cabinet up a few inches plus allowing me to move the damn thing around when it was loaded with media.
Good idea. I could see myself loosing smaller parts like bolts too.Get a nice fine strainer too. Go through your old media and you can salvage quite a bit.
This is true ^ kick, right to the balls lolBlasting is so mundane, yet so satisfying. Then when you pull it out and realize that you only got like 70% of it because the lights suck and the glass is fucked, FUCKKKKKKK
yuuuuup! I figured if I fix most of the issues now I'll be more inclined to fix the rest of them later. If it's too much a chore to do any blasting, I'll just never use the damn thing and let it take up space. lolBlasting is so mundane, yet so satisfying. Then when you pull it out and realize that you only got like 70% of it because the lights suck and the glass is fucked, FUCKKKKKKK
I did use the sticky liners, don't remember where I bought them from, the crappy ones they supply you allow media and dust to get in between the liner and the lower glass/acrylic. So the supplied ones got trashed quickly even before they got etched to the point you couldn't see through it.I'm leaning toward just cutting some acrylic and sticking liners to it. Even with the provided parts they aren't going to seal, because the factory put the foam strip on the wrong side. I will get some foam weather stripping from Lowes to fix that. Do you just use the lower window as the sacrificial piece? Do you not use the sticky liners?
I'm not super confident in my pick-up system, but I figured this was easy to do while there was no media in the hopper. I'm betting the crappy gun won't do it any favors either.
I think the LED strips will be okay because the housing is more of a rubbery gel that's meant to flex. I figure the media will bounce off of that a bit better, but it was cheap enough that I won't care either way. I may want to fill the electrical passage with a nice bulkhead though. Not only would it make light changes either but help seal the cabinet.
I'm 6'0" and it's too short for me. I will be making a wood platform for casters. There's no way I could hunch into that thing for more than 10 minutes. lol
I used Saran Wrap.We throw a clear vinyl cover on ours and replace it frequently.
