Bill Gates, the 1986 Grand Prix
Red Alert
Love this thing... my first car was an '86 Grand Prix LE. Same color too.
Great White Drake
You used to call me on my cell phone
Awesome, love g bodies. The vent has to be equal or taller than the highest point of the tank, which would probably be the filler neck.
C-450
Shoals, IN
Yea I was looking at it last night trying to figure out what to do with it. I thought about plugging it off but wasn't sure if the cap would allow it to vent. What do you think?
Great White Drake
Would have to see the cap, is it factory? I doubt it's a vent design in the 80's seeing as it points to the back of the car. My 60's cap vents and also fills behind the plate, but thats the 60's lol. I'd run the vent hose up the filler neck, but you most definitely need a vent for relief.
Great White Drake
Here's what my cap looks like, you can see the vents. I'm swapping a fi ls this winter and will still run the vent off the in tank pump.
C-450
Shoals, IN
Yea I don't have a cap like that. I can't say that mine is vented at all but it does have the filler behind the plate. I'll do what you said and run the hose next to the filler neck. I have noticed that it's causing my garage to smell like gas all the time now.
Great White Drake
Good, it's working. Easy fix is to run a charcoal canister in the vent line. Your car came with one from the factory if you still have it. Should be on the frame, front passenger side in the engine compartment.
C-450
Shoals, IN
The charcoal canister was installed in the left front side of a dumpster a few weeks ago. I'll have to do something different on that.
Mr. SBF
Keeping it Real with Ford Power!!!
Kenosha County
:rofl: Why is the turbo mounted up so high when there's so much room in that engine bay...:iorofl:
C-450
Shoals, IN
There was actually a good excuse for that. I was using left over pipe I had laying around. I had the turbo mounted lower but it wasn't going to clear the hood. So I said screw it. The good news is that I can lower it later on. The v band below the turbo makes it all interchangeable but the turbo isn't staying on long so I'll just have to buy more pipe later to mount one lower.
C-450
Shoals, IN
Did a little testing. Turbo chokes it down at 6000 rpm and the 4l80e wouldn't shift past 2nd gear. I replaced all the solenoids yesterday but I'm also having to replace the driver side brake caliper. I'll try to do a little better this week.
