now installed...but i have no way of testing it...
http://www.berryblab.com/
FAQ
http://www.berryblab.com/FAQ.aspx
FAQ
Once installed:
- Open the software
- Press the "BlackBerry Key" and select "Add Forum"
- Type in the full http://address.com/ to your forum, (where you extracted your zip file), including backslash.
That should be it. Your forum should be listed and you can now surf using your blackberry, natively. Use the "options" menu when you are viewing your forum to sign in.
This software comes with an Update Check for your BlackBerry, so you should only need to install it once on your phone and it will check for Updates everytime you connect with it.
