This car is really getting on my nerves.
Yesterday started off good though. I replaced the broken oil pressure sender connector. Now the dummy light works as it's supposed to.
Then I replaced one of the rear door switches since the dome light wouldn't come on if I opened it. I could make it flicker if I messed with the switch though. Easy fix. The new switches don't come with the rubber dust cover. I didn't know that they were so easy to swap over. I'll be saving these from now on!
That stuff was too easy. Plus, it was actually pretty nice out with lots of day light. I wanted to start figuring out the heated seat problem. Surely this will have something to do with it right? Note the dangling un connected wires and tar for some reason. ?‍
Started by cleaning that mess up, rebuilding connectors, and crimping a couple new terminals. Notice something else really odd about this seat? I didn't know until yesterday that there was another adjustment for these that could only be accessed from the back door! That's silly, Volvo. Why you do that?
Then I pulled the center console and all it's "contents". I think I'm immune to the rona now.
Bonus! I found a bad ground to the seat belt lights. That would explain their intermittent function. I just drilled a new hole for the self tapping screw.
I did some poking around with the multimeter and fixed a couple loose grounds, but unfortunately the main issue lies somewhere in the seat, because I have no continuity across its connector. Everything else checked out. It looks like I'll be pulling seat covers at some point to find a broken wire (super common) or something else that's dumb as hell because that would be more in-line with Moose's theme. No worries. I figured that was going to be the case. On the other hand, it still makes no sense that the switches don't illuminate. Oh well. I'll worry about what I know is bad first. It started to get dark, so I put things back together.
At least it looks nicer. This minor fail wasn't why I got irritated though. I went to run a quick errand and wouldn't you fucking know it?
The
damn
odometer
quit
AGAIN
I give up. If I ever get the rest of this car sorted out (heated seats, courtesy lights, heater valve) with the rest of the car behaving as it should, I'll spring the $500 or whatever it is to have the cluster completely refreshed. I'm not dicking with it anymore because I've officially exhausted all my knowledge and skills on that issue.
