Axle Weights....
rz79
I have a 2008 bullitt wit the standard 8.8 axle. I just put on steeda lower controls and was curious if i could remove the large lumps of rusty iron ford bolts to the tubes to help stop the wheel hop. I figured since i dont make huge h/p and have some very good lowers i could lose that estimated 16 lbs of wasted weight. Any thoughts? thanks.
Aron
If the rears are designed like GM does, I believe those are for harmonics. You may get a lot of drivetrain noise if you remove them.
rz79
rz79
hmmm.... I see. so maybe just leave them. Thanks man
Aron
Don't hold me to that info, but I'm almost sure
skyhighsd
auto mofo
Aron is right they are for harmonics, if you ask me pull them off and its easy enough one bolt each see if you notice anything. Mine have been off for over a year.
TCG Member 5219
Yep. I was going to remove mine too, but I have been lazy. They are pretty heavy pieces from what I hear too. I say do it, and if you hear gear whine and it bothers you, then put them back on.
TCG Member 5219
I just took mine off this weekend. I had to use the impact gun to get them off. But I can tell no difference. But they were heavy as shit though.
