So about 4 months ago I was changing the front diff mounts on my 13 Tahoe and I unbolted the right front CV shaft from the diff at the 6 bolt flange. Oddly diff fluid starts leaking out of the flange that I had unbolted so a put it back together right away. Now today I did an oil change and noticed fluid slowly leaking and has been sprayed in that area. Now, I thought that 6 bolt flange would be a dry connection. If it is actually supposed to be wet that when I disturbed that sealing area it would make sense to leak now. Or do you think it’s the axel seal at the end of the diff housing?
