This is a series of videos I made showing the process of converting an automatic 1998 MKIV Toyota Supra Turbo to a manual 6 speed transmission using a Grannas Racing T56 Magnum (TR6060) conversion kit.
Part 1: Tear down and preparation for conversion
Notes: This video will show process of removing the transmission in preparation for the clutch, master cylinder, transmission, and driveshaft install.
Part 2: Clutch, pedal, master cylinder install
Notes: This video will show process of installing the Mcloed RXT 1200 clutch, Tilton master cylinder, Grannas shifter panel, and clutch pedal installation. I also swap out my differential although that is not necessary for this swap.
Part 3: T56 Magnum modification and install
Notes: This video will go through the remaining installation of the transmission, throw out bearing, trans modifications and button up the remaining bits. I also do a little walk around of the finished product, talk about some of my struggles, and give my driving impressions.
I will also be doing a retrospective video now that I have been able to put some miles on the car and address some post conversion issues.
