your body is similar to my truck right?
with buckets and a console?
mine fit tight, but it fit.
Weird yours wouldn’t have space behind all that, what’s back there? The dash’s all have the same part number and doesn’t matter if it’s console or not.
I’ve heard the Bose shit sucks. So you bypassed the factory amp and used your own? Thankfully speakers are an easy swap on these.
I saw the same, my factory bose stuff woke up and sounds 100x better with my aftermarket head unit.
bass stopped clipping at higher levels.
it's definitely not as good as an entire replacement system, but it's much much much better.
There’s space behind all that though if you look. There’s the “back” of where the head unit sits which goes all the way down to where the switches go but there’s space behind that.I'm thinking the digital climate control is bigger than the manual like you have? deeper?
and then also, below the climate control in my truck, i have switches where you added your heated seat switches.
mine are for backup sensors, adjustable pedals, and traction control if i remember right.
So there's two levels of Bose, in 2013, so I'm betting you have the higher end one than me. Mine sounds good at all levels- again- not full blown replacement setup, but much better than the factory head unit had it sound
Do you have a sub in your center console from the factory?
sounds safe.
Sierra only had like half fancy stuff, though didn’t even have traction control. The Tahoe is a basic bitch. I do not miss the auto climate control. So slow to change from cold to hot. Kinda miss folding mirrors though.
