a car running 12.0 afr will be able to run more timing KR free vs. a car w/ 14.7.
He probably ran that at the same track that g9gt and gtp ran with incorrect mph's.
i dont know whats going on to be honest.
i did help push mikes car back to bp tho.
god i love that kid... i miss not getting jokes from him via text lately...
as i said before with PE enabled once you hit PE TP % YOU ARE NO LONGER IN CLOSED LOOP! ie the readings used by thingy (ltft's ) are not being adjusted in real time, so your tunning the top of the maf table with ltft's that lock in and just stay there in the log, while small changes may not need much of a change up top when you make larger changes, using locked in ft data isnt helping you, the riv kept repeatedly adding 1.xx% doing maf tunes with PE, without PE it was able to go to +12% we were able to dial it in in a day. sure mike doesnt have a crazy setup but just before the track day i did his exhaust and intake, the fastest way for him to tune where i felt it was safe for him to race was no pe street tuning before, and i made some changes and fattened the top end, i wanted him to log noPE on the way to the track and for the first few runs to collect that data (btw at one point he's +11% on just a few hit counts of just the track run data and on average +4-6% 7khz and up) so i could walk him through a quick track maf tune, enable PE and make some more data collection runs....well the track closed right before he was able to do so...not my fault.Still don't know why james does this nonsense, it's a friggin' grand prix, this type of tuning is a waste of time. If you command 12.2 and it runs at 12.1 then command 12.3 and bam, done. Who gives a shit if it's off a little bit, ur not tuning an 8 second car where something like this is important. GTPmikes car will remain slow until it actually has a tune and this nonsense is over with. I still don't think it went all the way down the track at 14.7afr, not possible without something giving IMO but i guess i could be wrong This is probably the (no offense james) dumbest thing to let someone do if it actually did run down the track that lean. Running a car at WOT with a 14.7afr...
