If they don't fix it I have an idea of exactly how to so we'll see.100% the sand, nature of the beast unless really bad
It's the outer edge. Size of a basketball divot...Stomp around it with your heels. You can move the sand around a little that way after the pool is filled.
No but since no subscription I'm interestedWaterGuru SENSE - Smart Pool Monitoring System
The SENSE device makes caring for your pool easy with our automated monitoring system and mobile app to be informed in real-time.waterguru.com
any of you guys know about this rig?
and 50$ every 6 months too....No but since no subscription I'm interested
Not at that price, less than $100 I might consider it. Literally takes me 5 min to test my chemicals once a week.
Tested yesterday, tad low on PH. So in under 10 min, I tested and added what was needed lol.
WaterGuru SENSE Cassette 3 Pack for Pool Monitoring
Hassle free pool monitoring. Our cassettes and their patented chemistry pads snap-in for easy replacement & last for 8 weeks.waterguru.com
In ground vs above ground I would imagine chemical testing/balancing similar, especially the testing part.i legit dont know what the fuck im doing though.
With a good test kit, its super easy once you get the hang of it. You just need to do some research on in ground pool chemical levels, meaning where they should be and how to add the chemicals.
https://tftestkits.net/TF-100-Test-Kit-p4.html
It didnt come with a laminated instruction card and the contents it shows listed and pictured werent all there?i bought this per your recommendation and tried to figure it out and just fucking couldn't. the instructions i was reading called for shit that wasn't in the fucking kit and i got annoyed as fuck and bought some shitty test strips from the walmart half a mile away because i wanted to get in the bitch and not have my skin fall off and i decided i could
Use the test strips. It’s all my dad used on his pool in Illinois and his liner lasted 14 years before it needed replacement.
Keep the PH and ALK in line and you’ll be fine. Keep a few 3” tabs in a floater.
Open early (I open end of April)
Close late ( I’m usually 1st-2nd week of October)
By doing this you prevent algae growth from the water getting warm before you can add chlorine. Heat burns off free chlorine.
During the season test regularly with strips. Set a scheduled day and time.
Shock after use. (I shock once a week whether we swam or not)
Check after rain fall as rain water will usually decrease PH.
It sounds involved but once you have a routine, it’s super easy.
I can take a pic of the instruction card when I get home.
Agree with everything said except the strips. I've used them in the past and once I switched over to a real test kit I'll never go back and will never recommend them. They dont read well enough and are inaccurate imo. Knowing your actual levels and understanding them prevents the "pool store water test". They will start selling you a bunch of shit you dont need and they use the same kit I use.Use the test strips. It’s all my dad used on his pool in Illinois and his liner lasted 14 years before it needed replacement.
We also shock once a week and shock after a lot of rain. But always balance your PH first and foremost before shocking.
Y are people shocking when your numbers are good?
Does it throw off all your other numbers? Or can you just leave it be after wards.
Shocking doesn't harm any of the other levels. The only thing shocking may change is your free chlorine levels which is usually a good thing as it is freeing it up.
