As title states. Or if anybody has any experience if the mudbugs make shipping to IL and still alive? Considering Louisiana crawfish company at the moment. Any crawfish boil advice appreciated also. Thanks in advance.
The process that my father in law taught me to do (true cajun born and raised and lives on the bayou):
As soon as you get the crawfish dump them out in a large tub of fresh water, I use one of those plastic kid pools, and you can let them soak and change the water once if you really want to clean them out good. Put a touch of salt in the soaking water all around. this helps force the crawfish to poop and clean them out.
Get your water heating up and add your dry boil seasonings and a touch of zatarans crab boil liquid. Directions for how much you need of these should be on the package. Only add about half a pot of water because it will raise up big time when you put all the crawfish in.
Once the water is at a full boil load up the crawfish into the basket and put it in the boil pot. Put the lid on. I like mine a little spicier so I let them boil a bit longer. Short boil times are mild and long boil times are spicy.
When you have boiled long enough pull out the basket and let the crawfish drain for a minute. Then dump the basket into a huge cooler. Season to taste with Tony chachere's seasoning over the top and stir the crawfish to distribute the seasoning. For 30lbs I usually use almost an entire standard sized jar. Let the crawfish marinade while you set up everything and get ready. They will stay plenty hot in a closed cooler for 15ish minutes.
Poor out cooler on large table covered with plastic drape and newspaper for easy cleanup. Eat some delicious swamp lobsters.
