I can't find a arm anywhere.. DamnAnd this is the case. I broke 2 different pitman arm pullers that I rented. That MFer will not fucking budge.
Issue now, is that I cant find a pitman arm anywhere, can find idler arms but no pitman arms.
Anyone know a place I can check locally or online for a 1971 Impala Pitman Arm
I'm assuming being its not a wear and tear type of item is whats making it hard to find
Dude, Ive been beating the piss out of the puller bolt with a 5lb sledge while under tensionSo once that remover is tight. Whack the end with a hammer.
Yes, but dont know anyone with a press. So that is my last option.Can you remove the gearbox with the pitman arm still on it? Then throw it in a hydraulic press?
With nothing gone right on this car, that is 100% expected.I bet even if it does come apart you'll find this, this is my arm off my box. View attachment 98789
I spent a hour searching online. If I could find one, I would cut the fucker off with my grinder.I can't find a arm anywhere.. Damn
I had an 08 Infinti G35xS Sedan for a few years, bought it used with 80k on it and paid good $$$ for an extended warranty. At the end of my ownership and still within the warranty period, I had 5-6 trips to the local Infiniti dealership for the power steering. They replaced/rebuilt the unit 3-4 times and in the last 4 months I owned that car, I was in a nice few different QX series SUV's for more than I was in my old G sedan. Not sure what the issue was, but as soon as it was fixed the last time I traded it in for my Jetta GLI that I had and haven't looked back!
Now we are talking lol. I just sprayed the piss out of it with Kroil and will let it sit overnight. If no luck tomorrow, I'll pull the gearbox and run it out to you.I've got a press here at work
MFing Kroil for the win. Came back out to the garage after the Kroil soaked for a hour. Thru some heat on her and she popped.
Love that shit!
Damn.. I wanted that mfer to bring me lunch
Also being that MFer is 28lbs and me laying on my back trying to balance it. Not fun lol.
Took the pitman arm of the center link as it kept getting in the way.Steering boxes blow dude. I'm glad you were able to get it apart, that's one of the worst parts of the job.
You might try separating the pitman arm from the center link, then you're not fighting with the box trying to get all that shit lined up.
Pro tip - don't put ATF in your power steering system, it'll make that shit leak like a fucking sieve.
My only advice was to spray everything with penetrant the night before.Now we are talking lol. I just sprayed the piss out of it with Kroil and will let it sit overnight. If no luck tomorrow, I'll pull the gearbox and run it out to you.
Whenever I do suspension work, I usually do that. Didnt really plan on doing this yesterday, had something cancel at work last minute.My only advice was to spray everything with penetrant the night before.
