Any turbo guys running
D
Drlee50
Sharkster said:
Ive heard programming the E-Boost2 is the same nightmare as programming the Greddy. plus both the Greddy Profec and the E-Boost 2 dont have fuzzy logic or self learning cycle. Looks like the E-Boost2 does the same thing as the AEM controller and its only $250
programing the eboost is simple. there are 3 buttons total. it can be set up for boost per gear, boost per rpm, locked boost level, program wastegate opening psi etc. i can reprogram my max boost level on the fly in about 10 seconds. i am not sure what self learning is. i just tell mine what to do and it does it. :dunno:
Painter
1,166
Fuck all that nonsense either get a Innovative or manual boost controller. I have a eboost 2 and hate it, the things more tempermental than my girlfriend. Everybody knows how to use an innovative and a manual is just as easy............hallmann makes a nice manual one. either way dont make the mistake I did and buy one thats a PITA to figure out. I'll sell you my eboost. :)
Sharkster
Addict
Sep 17, 2005
633
I can send you my Greddy and we can be equally disappointed haha
Im looking at a couple of manual 2 stagers. Hallman, Tubosmart, TurboXS etc... The only thing about the manual ones are the fear of overboosting or those damn WG's not opening on time.
Ray I am in absolute awe with these things. The power comes on so fast you cant really control it.
I had it out Sat for a little country driving. Heating it up and then looking for leaks and creaks. (all is good now) Im coming back into town and turn next to a funeral home. There was a funeral and everyone was leaving. A guy in a white C5 with the tops off is waiting to pull out of the lot and for me t ogo by. I make the turn and it was perfect timing. I hit the dip in the road and my foot mashed forward on the gas and they started to spool up, I pull my foot off and PPSSSSHTTTTTTTTTT they dump and wind down. I thought that guy in the vette was going to shit his drawers. He has his hand under his chin like "no way, no way" and then a thumbs up. The woman looked like she had pool cues taped to her head. Absolutely hilarious.... and I did it unintentionally :headbang:
Painter
1,166
Fun shit isn't it Jeff, I finally found an old country road between Crystal Lake and Marengo that I can make adjustments on, just over a mile long and straight as an arrow........I think I just might have my eboost figured out, 20lbs at 80 I got sideways, kinda scary but still fun. Do you have it tuned yet????????
Ray
Sharkster
Addict
Sep 17, 2005
633
Im still running off of SamBandits tune john looked it over and thought it looked pretty good
My FPDM's are on the way. Bumpsteers and a scavenge pump came today. I talked them into sending me the pump when I first saw the smoke. Im not seeing the smoke anymore. Ill hang on to it just in case.(Everythings starting to settle into place now) Ill put the bumpsteers on tomorrow afternoon and head to Janesville for an alignment. Ive got a 1/4 tank I need to burn down so the tank isnt that heavy when I drop it. When the Zone5 FPDM's get here then Ill have to drop the tank and put the GT40 pumps, wiring upgrade and new hose in there.... pull that damn PPRV out of there as well. John says its the difference of night and day.
Once I get those pumps in then Ill be on the horn with Kurgan and let him work his magic and see what she is really putting down.
It seems good 1-3 into 4th I dont want to hammer on it in those upper gears. I did hit it some in the lower gears. Ive got the Greddy hooked up but ill be dipped if I can figure out what numbers to start it off with. Its shut off and Im dumping through the wastegate springs, it looks like 7#'s when its dumping. Even that 7# comes on so strong and fast its like a ported and pullied eaton. WHAMOOOOO and your ass is gone and this thing gets all kinds of stupid
Oh I cant wait to get this thing up in the 17# range. Im thinking of that 2 stage manual with a low of 12# and a high of 17# or 18#
You running that 20# on pump or you splashing some Torco in there?
Sharkster
Addict
Sep 17, 2005
633
Profec B Spec II
Im tooling around the net looking for some beginner numbers to work with and I stumble across some guys on a Honda Civic forum explaining how to program this thing on an EVO 9. OK now thats absolutely sad. A twin turbo cobra going to a Civic site to learn how to use an EBC.
Regardless it gave me everything I needed to get this thing set. I was merely looking for a more refined instructions with some pointers. Greddy TAKE NOTE
Ill post it for the others that are still using this and cant figure it out
Please note: This writeup was taken from an evolutionm.net thread. It is NOT specific to SR20s but will help set you on the right path.
Before you begin, you should have an idea of what you're aiming for. For EVOs, 19psi (131 kPa) seems to be a safe setting based on what people on the forums have found since it is close to what the stock boost pressure is, yet there is an increase in power due to the Greddy unit keeping the boost close to 19psi while the stock boost tapers off as the RPMs increase. I will henceforth refer to what you're aiming for as "desired boost pressure".
Definitions and things you need to know before you start:
SET This is how you set the boost pressure. Rather than setting it in psi or kPa, the Greddy unit allows you to adjust it as a percentage value, from 0% (greddy unit essentially turned off) to 100% (greddy unit will set the boost as high as it can). This setup demands a certain amount of trial-and-error to properly configure it since you have to make adjustments, then drive under WOT (Wide Open Throttle) and see what the maximum boost pressure achieved was throughout the entire RPM range. SET SHOULD BE SET TO A CONSERVATIVE VALUE WHEN BEGINNING TO TUNE YOUR GREDDY UNIT. 30% SEEMS TO BE A CONSERVATIVE SETTING BASED ON MY TESTING AND BASED ON OTHER REPORTED NUMBERS FROM EVO OWNERS AND TAKING INTO CONSIDERATION THE LINK BETWEEN SET AND GAIN (see GAIN below).
GAIN is defined in the manual as the value to adjust the "boost consistency". You don't really need to know exactly what that means. You should set GAIN to 0 when beginning, and you will then test the car under WOT while paying attention to the boost pressure. If the boost goes up and then falls off at higher RPM, you will want to increase the GAIN by a conservative amount (5% should be relatively conservative to begin with, then when you want to fine-tune it, you can go down to intervals of 1%). When you increase the GAIN value, the corresponding boost that you will go up to will be higher even if you leave the SET value alone. GAIN SHOULD BE SET TO 0 WHEN BEGINNING TO TUNE YOUR GREDDY UNIT.
START BOOST (also known as SET GAIN because that is what is displayed on the unit when adjusting this setting) is the lowest boost that the Greddy unit will begin increasing the boost from under WOT. You want this to be as close to the SET value as possible, since you want to keep as close to your desired boost as possible. However, setting it too close to the SET value will cause the boost to spike. You should set this to a conservative setting when beginning to tune your Greddy unit. Then you can fine-tune it later to get it as close to the SET value as possible without causing the boost to spike. Fortunately, you can set this in psi or kPa, thankfully Greddy didn't decide to let this be adjustable in % like the SET value. START BOOST SHOULD BE SET TO YOUR DESIRED BOOST PRESSURE MINUS 4 PSI (about 28 kPa).
WARNING is the maximum boost that you do not want to exceed. Fortunately, you can also set this in psi or kPa like the START BOOST value. When the boost exceeds the WARNING level, it will kick in the LIMITER, which decreases the boost a certain amount that you can set. WARNING SHOULD BE SET TO YOUR DESIRED BOOST PRESSURE PLUS 1 PSI (about 7 kPa).
LIMITER is the boost percentage that the Greddy unit will lower to when the WARNING boost pressure is hit. LIMITER SHOULD BE SET TO YOUR SET VALUE MINUS 4%.
PEAK is the peak boost value that the unit has seen since the last time it was cleared. To clear it, go to the peak boost display, and hold down the set knob until the unit beeps and "---" is displayed. IT IS A GOOD IDEA TO CLEAR THIS BEFORE YOU BEGIN JUST IN CASE YOUR UNIT HAS A HIGH BOOST ALREADY RECORDED.
LAST BOOST shows you the last boost that was recorded every time the accelerator is released for 3 seconds. TURN LAST BOOST ON BECAUSE IT IS A GOOD DIAGNOSTIC TOOL WHEN TUNING YOUR UNIT.
Keep in mind that when displaying in kPa, it does not show it technically in kPa, but rather misleadingly in bars, which Greddy inconveniently tries to justify by sticking x100 kPa next to the display. Therefore, 100 kPa will be displayed as 1.00 x100 kPa. Psi will also unfortunately be displayed in psi x10 so that 19 psi will show as 190, adding to the confusion.
Another very important thing to keep in mind is that when you first power on your car or the Greddy unit, WARNING will be set to 14.5 psi (100kPa, or 1 bar) until you interact with the Greddy unit by pressing any button. This "feature" is not documented in the manual.
Also keep in mind that atmospheric conditions affect the operation of your boost controller. When it is hot, you will get different results than when it is cold. One possible way of solving this issue is tuning your Greddy unit under the "Lo" mode for when it is relatively cold, and under the "High" mode for when it is relatively hot. Unfortunately, two modes are hardly enough for somebody that needs to account for very different summer and winter climates, and also for more aggressive settings for when increased performance is desired.
The maximum boost that you will see is also not consistent throughout the gears, which adds even more to the confusion. Unfortunately, if you've already increased your start boost to the maximum setting that doesn't give you surging, then there seems to be no way to get around this variance in boost pressure from low to high gears. I don't know if this is a limitation of the greddy unit specifically, or if it's something inherent to electronic boost controllers in general. The only two things that you can do to compensate is the following:
1. Set it to the "safest" of the settings that does not trip your limiter. To do this, tune the unit to your desired boost pressure in fifth gear.
2. Tune the "Lo" and "Hi" settings corresponding to having the boost maximized during the low gears and during the high gears. This would require you to manually hit the button to switch to the "Hi" setting when you shift to third gear or whatever you started tuning your "Hi" setting at. This is why Greddy makes the wireless remote switch that straps to your steering wheel to switch between "Hi" and "Lo" settings.
The following steps should be taken in exactly this order, taking into consideration all of the previous information:
1. Change boost pressure units to psi if so desired (see manual).
2. Set WARNING to your desired boost pressure plus 1 psi (about 7 kPa) (see above).
3. Set START BOOST (SET GAIN) to your desired boost pressure minus 4 psi (about 28 kPa)(see above).
4. Clear PEAK boost value (see above).
5. Set LAST BOOST to ON (see above).
6. Set GAIN to 0 (see above).
7. Set SET to 30% (see above).
8. Set LIMITER to SET minus 4% (26% if you followed #7).
9. Test for boost falloff at high rpm. You should probably do this in a wide open area with no other cars nearby and preferably no cops. It is also good to have somebody in the car with you that can watch the gauge while you concentrate on not wrecking your car. If there is no boost falloff, then go to #10. If there is boost falloff, then increase the GAIN by 5% and test again. Keep in mind that when you increase the GAIN value, the corresponding boost that you will go up to will be higher even if you leave the SET value alone. Repeat until the boost pressure does not decrease, or until you feel surging. If you feel surging and the boost pressure still decreases (not sure if this is possible) then decrease to the last level that you did not feel surging at.
10. Increase SET by 2% and adjust LIMITER accordingly, then test again. Keep increasing by 2% until desired boost level is obtained.
11. Increase START BOOST (SET GAIN) by 1 increment and test until surging is felt or the WARNING level is hit and the display turns red, then decrease to the previous setting.
Once you have followed these steps, you will have roughly tuned your unit. To fine-tune it, repeat steps 9 and 10 except this time only increase or decrease by 1 increment.
Just to add something here...
the SET % is easy to figure out how it works. In the manual it says 0% is stock wastegate boost and 100% is max boost (wastegate hose disconnected)
So just take your max boost (MAX) and subtract your min boost (MIN) add 1...
take that number and divide it into 100 and youll get a numbr that corresponds with the percent you need to for each psi of boost...
so for a t25 MIN=7 Max=14 MAx-MIN+1=8 100/8=12.5
So for 8PSi SET should be 12.5... add 12.5 for each psi you want to increase over stock
  • S
  • 9
  • 343
