Any street tuners South East side of Chicago?
Unitsn4
Having some TCM issues I need help with.
TonzKnock-G
Shitcago
I will ask around but I really doubt it. All you see on the east side is mustangs and ricers. Im assuming you are using HP Tuners?
TonzKnock-G
Shitcago
What type of issues? Im sure someone on here can give you some advice.
Unitsn4
I have a couple of codes that are supposedly tuning related...or so I'm told. My harness manufacturer suggested I try and find a local tuner to come to me (or I can swing by if it's not very far) to straighten out the issues.
I don't have HP Tuners.
EmersonHart13
Member Selfie
So are you looking for someone with tuning software to tune it? If you use HP you will need to buy credits or find someone with an unlimited licenses for your LS3.
Unitsn4
I'm not looking for it be done for free. I just need someone who does this that has some time to tune it for me.
EmersonHart13
Member Selfie
It's typically $100 to buy the rights to tune a car in HP tuners. Then whatever they charge you.
Just letting you know what I know.
TonzKnock-G
Shitcago
Speed Inc would probably be the main suggestion here but im not sure if you could get it out there to them.
El Presidente
Speed is weeks out on work currently (or so the legend goes).
[MENTION=3559]School Boy[/MENTION], heads up.
EmersonHart13
Member Selfie
I think [MENTION=70]Smokinhot[/MENTION]'s brother does it or did it [MENTION=241]red04regencyrst[/MENTION] but he hasn't been on the forum in quite some time.
JBruno88
Carol Stream, IL
I know a guy. PM me details on the car, year make model, motor, trans, and mod list. He can probably get a tune ready for you in 2-3 days max and I have HP Tuners Pro and I'd be able to load it up for you.
Formula_LS1
Tim @ Sound Performance in Bensenville should be able to get you in somewhat quickly. PM me if you would like his contact info
Unitsn4
Thanks....the codes I have are P0717 and P0700. I'm told that the TCM isn't communicating correctly with the stock 11 Corvette ECM. I haven't been able to get a straight answer otherwise over at Ls1 tech.
Per RPM's warning...they suggested I don't drive the car at all with the codes. It seems to shift fine...just not when it's supposed to. I'm guessing that's due to it not having the correct tire size and rear end ratio programmed in. I don't want to do any damage to the recently built trans.
The P0717 is the VSS signal. The P0700 is automatic when there is a code pending.
Speed Inc is 6 weeks out for a dyno tune.
willizm
Ho fuckin Ho!
Saint John, IN
I sent you a pm. With the newest version of hptuners 2.24 you should be able to disable it under Trans diagnostics as p0717 is not a normal DTC and won't exist in the regular DTC list like all the other codes. If your interested in my help let me know but I figure i'd arm you with some information if whoever helps you is having issues finding it.
School Boy
Spray the cubic inch at it!
Thanks Mook.
[MENTION=11934]Unitsn4[/MENTION] PM me, I may be able to squeeze you in depending on what exactly needs to be done.
Unitsn4
School Boy and Speed Inc took care of the main issue I was having! Big thanks!!
