any mechanics in the house? please can you help me out?
bdyman
can i haz bondo?
cicero
having a problem with my 03 oldsmobile alero 2.2 ecotec
car sat for 3 yrs once a week ran the car, well as you see i finished the car, have been driving it allot, and now i have a p0420 code
iam leaving for lansing michigan next thursday morning, so i kinda need this fixed before i leave dont want to break down in the middle of no where with my kid in the car
iam unemployed dont have allot of money my personal mechanic is being a dick, but he says it could be a vacum leak or stuck injector, i dunno iam a body fender tech not a mechanic, so if you can fix my car i can fix your car kinda deal
i get discounts off parts but if someone can beat prices on parts i`ll go with what you have to offer, i need a starter for the same car please, also i need my tire fixed it has a leak in it anyone care to hook me up??
please people i need help bad
thanks
Eagle
Nemo me impune lacessit
Woodsticks, IL
P0420 means poor catalytic converter performance... if the car isn't noticeably driving any worse, or if your mileage hasn't decreased significantly - then I'd say you could probably roll with it. Have you tried just to have the code cleared to see if it returns? Chances are you probably have a bad rear o2 sensor.
As for the tire, why not just toss a can of stop leak in it?
Whats wrong with the starter? Called any junk yards for prices?
Eagle
Woodsticks, IL
Bad news is that it does seem like lots of people have had their cats fail, so if your cat is really dying (bad mileage, power decreases) then you really need to fix it. Parts should run about $150ish...
Good luck!
Angus
Bentonville, Arkansas
cats are legally suppose to last the lifetime of the vehicle, I thought... I would call up the service dept at your local gm dealership and you should be covered if it is cat related.
Eagle
Woodsticks, IL
I think GM is only obligated to replace it under 100k miles... but even then I don't think its easy to get them to do it. :dunno:
Sinister Drag Designs
SinisterDragDesigns.com
Chicago, IL
not a lifetime on any we have heard of. I know ford and few others offer up to 75k mile replacement as long as the o2's were working properly.
If you replace those or there working you can bring the car in for work. They can blame the failure on the sensors not working properly.
smug
Cedar Lake, IN
Under GM warranty for 8 years or 80,000 miles
B
bdyman
can i haz bondo?
cicero
sorry i didnt clearify, car runs fine gas mileage is fine, no rough idle, no black deposits from the exhuast, no vacum leak, cat was replaced before it went away, and i dont not want my local gm dealership to touch this car, its on air ride and if the tech forgets to release the air from the bags and blows a strut bag iam fucked!!!
so you guys think its the rear 02 sensor then??
B
bdyman
can i haz bondo?
cicero
ok i sure hope so, i did order a junk yard starter 30 bucks car has 16k on it, the tire iam going to go get it fixed,
other people are saying its my cat, are you sure its the rear 02 sensor??
Eagle
Woodsticks, IL
Sure? No... I haven't seen the car myself. If you can clear the codes yourself, pull the rear O2 and torch the exhaust end of it for about 4 minutes (yes, like with a MAP gas torch), reinstall it and clear the codes. If the code doesn't come back for a couple hundred miles, then its the sensor. Torching it cleans out some of the carbon build up and should allow it to function again for awhile...
You said you already replaced the cat once... so the chances of it being dead again is pretty slim unless you have a serious fueling issue and are dumping a ton of raw fuel out the exhaust. But you also stated that the car is running fine, so I doubt that's the case...
It's just my hunch. O2s are cheap tho, so it can't really hurt to give it a shot.
Sprayin
Public Enemy #1
Chicago, IL
If you can clear the codes yourself, pull the rear O2 and torch the exhaust end of it for about 4 minutes (yes, like with a MAP gas torch), reinstall it and clear the codes. If the code doesn't come back for a couple hundred miles, then its the sensor. Torching it cleans out some of the carbon build up and should allow it to function again for awhile....
Wouldnt that mean that there is something fouling out the sensor, and that while the sensor may be bad, there is a different problem that should be fixed before he just throws a new part at it?
B
bdyman
can i haz bondo?
cicero
right thats what iam saying, something is causing the code to come up, car has power, no rough idle, nothing wrong that i can feel or see, and i did buy a cheap obd2 reader from matco, it works and i cleared the code
fuck!! my mechanic is such a douche bag he wants to charge me to hook up his scan tool to check the injectors and the 02 sensors, i would so appreciate it if someone has a real scan tool and can scan my car, i would buff your car or something when i get back from michigan
anyone??
Eagle
Woodsticks, IL
A real scan tool isn't going to tell you much about your individual injectors, or O2s. They're pass fail, and since you've been clearing codes so much, chances are they haven't even ran through enough cycles to be in pass/fail state yet.
O2s often go bad in cars that don't get driven much, I'm jus sayin'.
Injectors DO get stuck open SOMETIMES, but if that was the case, it would idle like shit. The more common scenario would be a clogged injector... WHICH WOULDN'T CAUSE A SENSOR TO FAIL...
It's cool tho. Over analyze everything I tell you. Did you torch the old O2 yet? Did you even take it out to see how crappy it looks?
Eh, I think I've covered the bases here. Good luck with your fix.
B
bdyman
can i haz bondo?
cicero
iam going to my buddies house saturday so iam going to do wut you said to do
thanks again
