Used the A/C today on my 2003 Cobra and it felt not as cold as usual (probably some refrigerant leaked out from sitting all winter), so I put a gauge on the low side port and only got 22 psi. I have a chart that says it should be between 40 and 50 PSI with an outside temp of 83 degrees. Is this correct?
Also, I have conflicting information about how much refrigerant the system can take. I think the correct amount is 34 ounces (with about 8 ounces of oil), but then I have some other specs that say 17 ounces. Can anyone verify which number is correct? I don't want to accidentally blow up the system by overcharging.
