So after installing the LDC free-play kit I was hearing a high pitched whine when driving. I figured it was due to the cover over where the clutch cable connects to the trans not being on tight enough, so I checked it out and the "weather" stripping on one side of the aluminum case had been torn off. I picked up some new stuff and put it on, but now it almost seems worse. I've got the cable adjusted for about 1/8th in of slack, so I don't think it' the adjustment of it. It almost looks like the "fork" that the clutch cable connects to is hitting the casing??? I remember that fork moving a little when I did the install, is there a way that could have gotten screwed up at all somehow?
I'm reaching here, but the rattle is really annoying when driving... Thanks!
