1quick
26,608
24,185
coal city
I'm not sure. I can't bring it to stall speed.
Idle is about 14 in hg.
I know it’s in the title of the thread but I totally forgot this was a blower car lol, I was buzzed up talking about brining a turbo car up on the converter to build boost last night lol, did you try to just take up up off idle a bit and flash the converter at launch, my car 60’s the hardest from like 1500-1600 rpm and stab it off the light apples to oranges but if you have a stock or zzp converter it should flash pretty good
GTPpower
6,344
9,742
Nebraska
I didn't try that. I've always had the best luck stalling it up. Plus, with bracket racing, I'm way more consistent stalling it up. But I will have to keep that in mind the next time I go to the track. There is a zzp 2500 stall in the car.
GTPpower
6,344
9,742
Nebraska
So I've been super vague about the intercooler on this car, and that's not by accident. I was thinking about reproducing these kits, but they are a huge pita to make. So here is what I did.
I welded a plate over the opening of the lim to block it off.
Made some new blower mounts.
Had some machine work done to the exterior of the blower case.
After that, I was able to drop it in upside down.
I cut a hole in the lim for air inlet.
Mocked up the inlet pipe and welded a box over the plate on top of the blower.
Started to mock up my charge pipes. I used and old thrasher nitrous TB spacer for a TB flange.
Welding some of these aluminum charge pipes.
Some welds look decent, some look terrible. Part of my problem is trying to weld 1/2" aluminum with a welder rated for 3/16".
Mocked up the intercooler.
