Drag to reposition cover
An m90 build to decimate all
GTPpower
GTPpower
Posts
3,928
Nebraska
I would have got more done, but my dad stopped by with his 1990 f250. It has a 351w and sounds like it's running on maybe 4 cylinders. I worked on it for awhile, but I don't know how to diagnose if I can't plug a computer into it.
RdRnnR
wannabe racecar builder
Posts
1,246
nebraska
I did clean off my bench though. I can see it now. That's good at least. It was bad.
That makes all the difference in the world man. I'm So damn close on mine I just keep siftin through the pile but as soon as it runs again irs all gettin cleaned up and rearranged. I gotta give up the farm shop life 😂
Posts
27,891
People screw up the firing order on the 351 Windsors all the time so start with that before you go much further.
It's also very common for the TFI ignition module in the distributor to die and that's why that f250 truck should have the module located on a heatsink on the inner Fender... but it may not.
Posts
27,891
God i don't miss eecIV Diagnostics....
Also another major failure point is the two large salt and pepper shaker electrical connectors the female terminals tend to get spread and no longer grab properly causing injector/tps issues that do not trigger codes
RdRnnR
Posts
1,246
nebraska
Sounds like gettin a spark tester and a multimeter out to me. Alot of that Era of stuff works on resistance and analog signal rather than the switches and self diagnostics we have today. I'm not super familiar with the ford's ignition system but I know alot of those trucks found boneyards over misfires. And the emissions caused alot of hell as well
If you get further into it and can get any info holler at me I got a cousin up by you whose into that Era ford's pretty deep that can probably help off the top of his head as well
Posts
27,891
The EGR issue generally happens more often after a steady Cruise drive and rears its head at the first stop you come to after getting off the highway
An easy way to be able to rule this out is to remove the two bolts holding the EGR to the intake and making a block off gasket using the side of a cereal box.
Sometimes the chunk of carbon will not break apart and get out of there
RdRnnR
Posts
1,246
nebraska
This. Or isn't there a steam pipe kinda thing in the back that rots out?
Posts
27,891
Actually yeah there is a rubber elbow that goes to the PCV valve at the center rear of the lower intake.... and below the PCV valve rubber grommet that gets brittle and breaks is the oil separator screen that tends to turn into a block of carbon after a year or two.
Posts
27,891
You'll probably get lucky and the rubber grommet will just lift right out of the intake hole. But you're probably not going to be able to get the screen lock out without running in a couple of 3 inch long drywall screws and using vice grips and maybe a pry bar to work it up out of the intake.
You will want to ask for a PCV screen PCV valve grommet and PCV valve and valve elbow although if I recall you can generally take off a 90 degree spark plug wire Boot and make it work
Posts
27,891
If the Breather filter in the air box is oily as well as 1 edge of the air filter you likely have a clogged screen at least and your engine is blowing blow-by out through the fresh air Inlet pipe
GTPpower
GTPpower
Posts
3,928
Nebraska
I guess I should mention, this thing is all original. It has about 70k miles on it, and gets driven maybe 200 miles a year. I would have at least pulled the plugs to look at them, but that thing is an emissions nightmare. There is crap everywhere in the engine bay.
RdRnnR
Posts
1,246
nebraska
Yep. Vacuum pumps and smog pumps and stupid little pipes and all the other mid 80s and early 90s hell before they halfway figured out what they were doin. Thank God for obd2 and mpfi
RdRnnR
Posts
1,246
nebraska
Dont be a pussy i slung wrenches on em all the time.
.... you can b**** when it's got a hundred ninety Thousand Miles and been a plow truck for the last 10 years.
Thats what they all are here 😂 that bein said I'll take early Ford emissions over beatin split rims and chloride filled farm tires for the last couple decades
GTPpower
GTPpower
Posts
3,928
Nebraska
I was able to work on the car for maybe a half hour yesterday. I'd really like to get this thing running.
So maybe everyone knows this, but it's incredibly hard to check powersteering fluid on the fwd cars... especially mine with all the crap in the way and the alternator moved back. So I went to the junkyard and got a power steering pump extension and dipstick from a 95 blazer.
Cleaned it up a bit and welded a tab on it to mount to the alternator bracket. Still need to cut off the excess, drill the bolt hole, and paint it.
My weld kind of sucked there, but it's getting painted.
GTPpower
GTPpower
Posts
3,928
Nebraska
thats a great idea. i always hated checking/filling them...
maybe there is a market for thses to be sold? :unsure: get on it!
There might be. They only take a couple minutes to get out at the junkyard, and cost about $8 with tax. I'd have to test fit it on a normal car since my alternator is moved back an inch or so though.
Why this was not a factory item, I'm sure we can blame the bean counters.
