v6buicks
6,353
15,766
Franklin, IN
Jon
I think I'm going to pull it out after Friday and send it to someone that knows what they are doing.
Autos in general are like voodoo to me. Even when you're sure you've done everything right, something isn't right. Any idea who you're going to try? With TEP out of the game, I'm not sure where else to turn anymore.
Reactions: GTPpower
GTPpower
6,345
9,746
Nebraska
Nichols in Kansas City has received most of Dave's business. I might take to there since that's a 4 hour drive for me. Otherwise there is Harmon performance transmission in Minnesota I think. Or the guy that has been helping me with it, who I think is in Michigan. Or I might try to sweet talk Dave into looking at it. I'll have to do some calling around.
Reactions: v6buicks
GTPpower
6,345
9,746
Nebraska
Well, I think with help I have a solution.
I used a bonded separate plate with a paper gasket on each side like the manual says to. But since it's bonded, you aren't supposed to use the paper gaskets. Doing that will cause no 1st and 4th. So, it'll be a pain, but I should be able to fix this without dropping the trans.
GTPpower
6,345
9,746
Nebraska
Explain that one to me more.... I have this exact problem right now with my '97 LeSabre, I thought it was a shift solenoid issue.
The manual shows to install the separate plate (spacer) in the middle with a gasket on each side.
I used this during the rebuild. But, I didn't see anything that said not to use gaskets on it.
It has the gaskets already attached, so if you use gaskets like the manual shows to, it will keep you from having 1st and 4th. I will try to show the differences in the gasket and separate plate when I get it apart.
GTPpower
6,345
9,746
Nebraska
Dropping the subframe on the driver's side to get to the valve body.
If you look really close, you can see where the check ball tried to year through the paper gasket to allow flow for 1st gear.
There's also lots of places where the passages don't line up.
Pulled the paper gaskets off and got it all put back together. I'll put in a new filter and fluid before I take it for a test drive.
Mr_Roboto
25,867
31,018
Yeah, a little fuckery will cause shit to happen. Back in the day I bent the corner of a VB gasket less than 1/4 inch installing it. Had to fucking drop the VB to fix it. I'm doing the Transgo HD Kit in my 700R4 so I am hoping to avoid similar fun again.
Ron Vogel
5,175
4,286
Ron Vogel
When I did my wife’s trans, I used the tq converter bolts to pull it into the flexplate (Don’t do this) . It didn’t sit right and killed the pump bushing. I had to pull the whole assembly out to replace a $3 bushing, and $6 seal. Found out you pull the TQ converter forward from the backside towards the flexplate to properly clock it. Then tighten. Been fine since
GTPpower
6,345
9,746
Nebraska
Whats the highest hp FWD engine GM makes now? Itd be killer to stuff a say 360+ hp 8 speed or whatever with a 100 shot and send it. I should look it up and just find a wreck so youve got everything. Electronics and all.
I have no idea. No way I'd have the time to do something like that. I'm slowly getting the kinks worked out. This thing should be nearing 400 whp.
Reactions: Rent Free
Ron Vogel
5,175
4,286
Ron Vogel
If you really want to know, use your trap speed. It’s the most accurate way to determine HP
L67’s don’t dyno right. Witnessed it on many occasions, and even my own car.
