Aluminum calipers
I
imported_Ron Vogel
I'm looking to lighten the load, I could care less if the car stops or not; hehe...Anyway, are there any GM calipers that will work on the stock size rotor that are aluminum? I have seen some Malibu's with aluminum one's, but don't know if they will bolt up. I'm rebuilding my LCA's in the next couple of weeks, and want to get a bunch of stuff done, while it's all apart. TIA
98 TGP TOY
Morton, IL
Stocksize I dont know about, but the f-body upgrade is suppose to shed a couple pounds. You loose a lot with the calipers, and gains some back with the larger rotor.
I
imported_Ron Vogel
Yup, you add 2lbs of rotating mass per wheel; trying to avoid that. I'm working on lightening/stiffening the front suspension. I've got some new LCA's on the way that I will be lightening, then adding solid bushings to (hopefully can do roller bearings, but have already sourced an upgrade to the crappy forward mount).
98 TGP TOY
Morton, IL
Thats what I figured. The other thing, though probably un-feasible and impossible. If the f-body rotors are the same thickness as our, couldnt you just get the last inch machined off.... :unsure: :blink:
LP 3800
I am pretty sure that machining that much, would warp it.
This would be a good thing to know Ron. I also need to lighten the car and myself a little bit these days :)
I
imported_Ron Vogel
I don't know how much I can get off of the LCA's, but they need to be stiffened up for sure. I had a brace for the drivers side LCA I used at the track, and with it on the car pulled incredibly better with it on. I snapped it off at my last track day, so there is some extreme movement there. If what I'm doing ends up being successful I'll share.
toastyj
The best way to lighten the car is actually to stop eating cupcakes and start eating apples...
BUT REALLY, what is the is that suspension kit upgrade or whatnot that you guys are talking about? Anyone mind filling me in?
I
imported_Ron Vogel
Just got the info from Zoomer. The Grand Am, or N-body calipers fit. :D
I
imported_Ron Vogel
OK, I checked out part #'s and the Grand am V6 is the one to use. However, it may cause some troubs. The rotor diameter is essentially the same, but the rotor thickness is thinner for the GA. So, it may work, but you may need to shave the pads a little. The caliper for the rear is the same used on the GP. Next month I'll pick some up and play with it.
