AFC tune need how to
ithurtz
Jan 19, 2015
55
3
Antioch
It appears GPF has nobody that knows how or what to do with a afc so here I am after lurking for a long time.
Long story short, have cammed turbo gtpt, maf rings over 13,500 so need afc. Dont know how to scale anything.
Fixed afc says it reduced 18% and to multiply maf by 1.45. So we figure reduce the maf by 18%, attached afc, flashed, car wouldnt stay running, wb was flatlined (highest it can read is 18:1)
Left afc attached, put maf back to previous, wb flat lined, with touching the throttle car stayed running a little longer
Added 1.45 in the units, wb flat lined same as above. SO wtf?
Pulled the afc off, flashed back to my previous tune and awaiting instructions for this thing.
I have DHP, need pictures or a very good explanation of how to do this. Car is parked again now anyway after 2 days of 60 so its not like I am in a SUPER rush and the roads will be dirty now.
Oh, and its running a stock tbody, stock maf and I wont be changing it. Mods are cartuning turbo, stattama stage 2 turbo cam, ported heads, #60lb injectors if any of that matters.
25,942
5,810
I'm not sure how DHP works, but couldn't you just highlight all of the cells, copy them, put them on an excel sheet, multiply them, copy them again, and paste them back into DHP?
If it was super lean I feel like you went the wrong way with the multiplication.
Do you know how to scan the maf readings while the car is running? You can see what part of the maf table the car is idling at to see why it's running like shit. I use HPT so I really can't help as much as I want, but when you scale the maf it should read higher in every cell. So instead of maxing out the maf at 13500hz, that area in the maf table should be much lower in the maf table, do you know what I mean?
ithurtz
Jan 19, 2015
55
3
Antioch
Had a chance to flash it over today, only sat in the driveway, car actually ran this time and stayed running. Idle seems lean now, 02 sensor seems to get funky looking at a quick scan. Now onto some decent weather so I can tune tune kaboom.
INJ PW KR LTFT MAF 02 SPARK
0 00:00:00:000 1.785 0 14.843 2318.359 907.06 24.5
1 00:00:00:406 1.937 0 14.843 2349.609 854.98 24.5
2 00:00:00:750 1.831 0 14.843 2318.847 915.74 24.5
3 00:00:01:109 1.8 0 14.843 2386.718 894.04 24.5
4 00:00:01:531 1.876 0 14.843 2367.675 611.94 24.5
5 00:00:01:953 1.907 0 14.843 2375.976 868 24
6 00:00:02:375 1.831 0 14.843 2357.91 850.64 24.5
7 00:00:02:750 1.937 0 14.843 2349.609 863.66 24
8 00:00:03:172 1.632 0 14.843 2306.152 850.64 24
9 00:00:03:593 1.8 0 14.843 2255.371 815.92 24
10 00:00:03:953 1.861 0 14.843 2310.058 746.48 24
11 00:00:04:390 1.907 0 14.843 2291.503 898.38 24
12 00:00:04:797 1.846 0 14.843 2301.269 898.38 24
13 00:00:05:172 1.876 0 14.843 2312.5 863.66 24
14 00:00:05:547 1.831 0 14.843 2345.214 781.2 24
15 00:00:05:922 1.876 0 14.843 2310.546 854.98 24
16 00:00:06:359 1.876 0 14.843 2307.617 377.58 24
17 00:00:06:765 1.876 0 14.843 2316.894 785.54 24
18 00:00:07:125 1.953 0 14.843 2302.734 177.94 24
19 00:00:07:562 1.983 0 14.843 2290.039 108.5 24
20 00:00:08:015 1.968 0 14.843 2378.906 82.46 23.5
21 00:00:08:390 1.831 0 14.843 2338.378 872.34 24
22 00:00:08:750 1.815 0 14.843 2326.66 837.62 23.5
23 00:00:09:187 1.846 0 14.843 2325.683 173.6 23.5
24 00:00:09:609 1.876 0 14.843 2312.011 911.4 23.5
25 00:00:09:953 1.846 0 14.843 2292.48 902.72 23.5
26 00:00:10:390 1.876 0 14.843 2318.847 902.72 23.5
27 00:00:10:718 1.861 0 14.843 2264.16 872.34 23.5
28 00:00:11:156 1.953 0 14.843 2311.035 876.68 23.5
29 00:00:11:562 1.77 0 14.843 2307.128 824.6 23.5
30 00:00:11:937 1.846 0 14.843 2329.101 590.24 23.5
31 00:00:12:375 1.861 0 14.843 2302.734 881.02 23.5
32 00:00:12:781 1.876 0 14.843 2323.73 846.3 23.5
33 00:00:13:218 1.937 0 14.843 2314.941 889.7 23.5
34 00:00:13:547 1.846 0 14.843 2245.117 872.34 23
35 00:00:14:015 2.044 0 14.843 2312.5 720.44 23
36 00:00:14:422 1.892 0 14.843 2287.109 868 23
37 00:00:14:750 2.014 0 14.843 2323.73 846.3 23.5
38 00:00:15:172 1.846 0 14.843 2311.523 894.04 23
39 00:00:15:547 1.953 0 14.843 2275.878 555.52 23
40 00:00:15:968 1.876 0 14.843 2300.781 138.88 23
41 00:00:16:406 1.815 0 14.843 2343.261 872.34 23
42 00:00:16:734 1.846 0 14.843 2319.824 889.7 23
43 00:00:17:172 1.907 0 14.843 2329.589 833.28 23
44 00:00:17:578 1.907 0 14.843 2323.242 885.36 23
45 00:00:17:953 1.861 0 14.843 2321.289 881.02 23
46 00:00:18:375 1.892 0 14.843 2290.527 876.68 22.5
47 00:00:18:797 1.922 0 14.843 2296.386 850.64 23
48 00:00:19:218 1.861 0 14.843 2324.218 841.96 23
49 00:00:19:609 2.09 0 14.843 2334.96 850.64 23
50 00:00:20:062 1.831 0 14.843 2334.472 611.94 23
51 00:00:20:422 1.892 0 14.843 2369.14 872.34 23
52 00:00:20:797 1.892 0 14.843 2309.082 876.68 23
53 00:00:21:234 1.892 0 14.843 2321.777 876.68 23
54 00:00:21:640 1.861 0 14.843 2309.082 846.3 22.5
55 00:00:21:968 1.876 0 14.843 2298.828 850.64 22.5
56 00:00:22:406 1.922 0 14.843 2294.921 876.68 22.5
57 00:00:22:750 1.968 0 14.843 2361.816 876.68 22.5
58 00:00:23:203 1.907 0 14.843 2339.355 763.84 22.5
59 00:00:23:609 1.861 0 14.843 2268.554 711.76 22.5
60 00:00:23:937 1.815 0 14.843 2327.636 859.32 22.5
61 00:00:24:422 1.922 0 14.843 2336.914 559.86 22.5
62 00:00:24:797 1.876 0 14.843 2303.71 872.34 22.5
63 00:00:25:172 1.892 0 14.843 2315.429 321.16 22.5
64 00:00:25:578 1.846 0 14.843 2332.031 60.76 22.5
65 00:00:25:953 1.77 0 14.843 2385.253 60.76 22.5
66 00:00:26:453 1.922 0 14.843 2372.558 82.46 22.5
67 00:00:26:781 1.968 0 14.843 2319.824 442.68 22.5
68 00:00:27:140 1.983 0 14.843 2324.218 881.02 22.5
69 00:00:27:562 1.953 0 14.843 2314.941 907.06 22
70 00:00:27:984 1.937 0 14.843 2345.214 894.04 22.5
71 00:00:28:422 1.937 0 14.843 2315.429 876.68 22
72 00:00:28:765 1.876 0 14.843 2341.796 863.66 22
73 00:00:29:203 1.892 0 14.843 2327.148 863.66 22
74 00:00:29:609 1.922 0 14.843 2349.609 876.68 22
75 00:00:29:937 1.8 0 14.843 2310.058 876.68 22
76 00:00:30:422 1.983 0 14.843 2311.523 768.18 22
77 00:00:30:765 1.846 0 14.843 2346.679 846.3 22
78 00:00:31:187 1.892 0 14.843 2312.5 872.34 22
79 00:00:31:578 1.907 0 14.843 2341.796 846.3 22
80 00:00:31:953 1.922 0 14.843 2314.941 820.26 22
81 00:00:32:390 1.968 0 14.843 2330.078 342.86 22
82 00:00:32:781 1.937 0 14.843 2338.867 99.82 22
83 00:00:33:156 1.8 0 14.843 2312.988 854.98 22
84 00:00:33:578 1.892 0 14.843 2351.074 529.48 22
85 00:00:34:015 1.785 0 14.843 2309.082 885.36 22
86 00:00:34:422 1.846 0 14.843 2278.32 863.66 21.5
87 00:00:34:781 1.968 0 14.843 2261.718 607.6 21.5
88 00:00:35:109 1.861 0 14.843 2329.101 872.34 22
89 00:00:35:547 1.892 0 14.843 2319.824 868 21.5
90 00:00:36:109 1.953 0 14.843 2348.144 863.66 22
91 00:00:36:406 1.876 0 14.843 2311.523 876.68 21.5
92 00:00:36:734 1.876 0 14.843 2334.472 824.6 21.5
93 00:00:37:203 1.785 0 14.843 2313.964 863.66 21.5
94 00:00:37:625 1.831 0 14.843 2310.546 881.02 21.5
95 00:00:37:968 1.953 0 14.843 2338.378 898.38 21.5
96 00:00:38:406 1.907 0 14.843 2321.289 863.66 21.5
97 00:00:38:812 1.876 0 14.843 2352.539 798.56 21.5
98 00:00:39:250 1.77 0 14.843 2291.503 815.92 21.5
99 00:00:39:562 1.876 0 14.843 2301.757 659.68 21.5
100 00:00:39:937 1.922 0 14.843 2328.125 104.16 21.5
101 00:00:40:375 1.937 0 14.843 2321.777 99.82 21
102 00:00:40:797 1.815 0 14.843 2314.941 611.94 21
103 00:00:41:203 1.922 0 14.843 2337.402 889.7 21
104 00:00:41:593 1.876 0 14.843 2330.078 868 21
105 00:00:42:000 1.831 0 14.843 2307.128 889.7 21
106 00:00:42:422 1.922 0 14.843 2303.222 876.68 21
107 00:00:42:765 1.907 0 14.843 2311.523 881.02 21
108 00:00:43:203 2.075 0 14.843 2342.285 815.92 21
109 00:00:43:609 1.907 0 14.843 2326.66 295.12 21
110 00:00:43:984 1.876 0 14.843 2359.375 863.66 21
111 00:00:44:375 1.907 0 14.843 2324.218 881.02 21
112 00:00:44:750 1.922 0 14.843 2373.046 868 21
113 00:00:45:172 1.922 0 14.843 2336.914 894.04 20.5
114 00:00:45:578 1.907 0 14.843 2324.218 889.7 20.5
115 00:00:45:953 1.892 0 14.843 2354.492 815.92 21
116 00:00:46:406 1.846 0 14.843 2327.636 872.34 20.5
117 00:00:46:812 1.77 0 14.843 2312.988 833.28 20.5
118 00:00:47:250 1.998 0 14.843 2281.25 464.38 20.5
119 00:00:47:593 1.892 0 14.843 2292.48 885.36 20.5
120 00:00:48:031 1.861 0 0 2322.265 889.7 20.5
121 00:00:48:422 1.922 0 14.843 2318.359 820.26 21
122 00:00:48:765 1.998 0 14.843 2309.082 125.86 21
123 00:00:49:203 1.815 0 14.843 2365.722 889.7 21.5
124 00:00:49:562 1.922 0 14.843 2333.496 807.24 21
125 00:00:49:984 1.892 0 14.843 2317.871 156.24 21
126 00:00:50:406 1.846 0 14.843 2324.707 881.02 21
127 00:00:50:828 1.846 0 14.843 2316.894 881.02 21
128 00:00:51:187 1.907 0 14.843 2339.355 868 21
129 00:00:51:593 1.953 0 14.843 2310.058 889.7 20.5
130 00:00:52:047 1.922 0 14.843 2306.152 811.58 20.5
131 00:00:52:390 1.968 0 14.843 2368.164 863.66 20.5
132 00:00:52:828 1.907 0 14.843 2334.96 885.36 20.5
133 00:00:53:250 1.754 0 14.843 2333.984 668.36 20.5
134 00:00:53:578 1.892 0 14.843 2317.382 859.32 20.5
135 00:00:54:015 1.8 0 14.843 2319.335 789.88 20.5
136 00:00:54:359 1.922 0 14.843 2308.593 854.98 20.5
137 00:00:54:781 1.8 0 0 2307.128 151.9 20.5
138 00:00:55:218 1.922 0 14.843 2351.074 802.9 20.5
139 00:00:55:562 1.922 0 0 2305.664 47.74 20.5
140 00:00:56:000 1.922 0 0 2373.046 69.44 20.5
141 00:00:56:422 1.892 0 0 2329.589 47.74 20.5
142 00:00:56:781 1.876 0 0 2383.789 30.38 20.5
143 00:00:57:203 1.953 0 0 2391.601 43.4 20.5
144 00:00:57:625 1.861 0 0 2340.332 47.74 20.5
145 00:00:58:062 1.892 0 0 2380.371 104.16 20.5
146 00:00:58:390 1.892 0 0.781 2377.929 60.76 20.5
147 00:00:58:734 1.846 0 0.781 2371.093 91.14 20.5
148 00:00:59:172 1.785 0 1.562 2354.492 642.32 20.5
149 00:00:59:593 1.861 0 1.562 2327.636 282.1 20.5
150 00:01:00:015 1.785 0 2.343 2281.25 442.68 20.5
151 00:01:00:390 1.846 0 2.343 2262.695 881.02 20.5
152 00:01:00:843 1.983 0 3.125 2319.335 881.02 20.5
153 00:01:01:234 1.8 0 3.125 2302.734 907.06 20.5
154 00:01:01:578 2.075 0 3.906 2270.019 846.3 20.5
155 00:01:02:015 1.953 0 4.687 2314.941 824.6 20.5
156 00:01:02:437 1.876 0 4.687 2318.359 872.34 20.5
157 00:01:02:797 1.968 0 5.468 2280.761 729.12 20.5
158 00:01:03:203 1.892 0 5.468 2325.683 894.04 20.5
159 00:01:03:547 1.831 0 6.25 2311.523 850.64 20.5
160 00:01:04:015 1.998 0 6.25 2367.675 894.04 20.5
161 00:01:04:422 1.922 0 7.031 2326.171 876.68 20.5
162 00:01:04:750 1.831 0 7.031 2310.058 902.72 20.5
163 00:01:05:187 1.937 0 7.812 2259.765 811.58 20.5
164 00:01:05:609 1.983 0 7.812 2307.617 898.38 20.5
165 00:01:06:047 1.907 0 8.593 2299.804 894.04 20.5
166 00:01:06:406 1.892 0 8.593 2308.593 898.38 20.5
167 00:01:06:859 1.968 0 9.375 2330.078 889.7 20.5
168 00:01:07:250 1.846 0 9.375 2282.226 894.04 20.5
169 00:01:07:609 1.8 0 10.156 2280.273 894.04 20.5
170 00:01:08:015 1.922 0 10.156 2260.253 837.62 20.5
171 00:01:08:375 1.861 0 10.937 2309.082 911.4 20.5
172 00:01:08:812 1.922 0 10.937 2318.359 894.04 20.5
173 00:01:09:218 1.892 0 11.718 2291.015 885.36 20.5
174 00:01:09:562 1.968 0 11.718 2280.273 781.2 20.5
175 00:01:10:031 1.876 0 12.5 2318.847 889.7 20.5
176 00:01:10:422 1.861 0 12.5 2312.011 881.02 20.5
177 00:01:10:781 1.922 0 13.281 2288.574 768.18 20.5
178 00:01:11:218 1.861 0 13.281 2283.203 885.36 20.5
179 00:01:11:640 1.968 0 13.281 2319.335 863.66 20.5
180 00:01:12:078 1.861 0 13.281 2299.316 859.32 20.5
181 00:01:12:390 1.861 0 13.281 2316.406 841.96 20.5
182 00:01:12:734 1.922 0 13.281 2289.062 841.96 20.5
183 00:01:13:187 1.846 0 13.281 2311.523 876.68 20.5
184 00:01:13:593 1.937 0 13.281 2264.648 811.58 20.5
185 00:01:14:031 1.831 0 13.281 2307.617 651 20.5
186 00:01:14:375 1.861 0 13.281 2354.492 677.04 20.5
187 00:01:14:812 1.892 0 13.281 2355.957 833.28 20.5
188 00:01:15:234 1.861 0 13.281 2373.535 329.84 20.5
189 00:01:15:578 1.922 0 13.281 2343.261 147.56 20.5
190 00:01:16:078 1.892 0 13.281 2345.214 841.96 20.5
191 00:01:16:437 1.922 0 13.281 2316.406 876.68 20.5
192 00:01:16:781 1.861 0 13.281 2308.593 881.02 20.5
193 00:01:17:187 1.846 0 13.281 2312.988 859.32 20.5
194 00:01:17:578 1.831 0 13.281 2333.007 859.32 20.5
195 00:01:18:015 1.861 0 13.281 2342.285 824.6 20.5
196 00:01:18:422 1.907 0 13.281 2346.679 199.64 20.5
197 00:01:18:750 1.785 0 13.281 2319.335 659.68 20.5
198 00:01:19:203 1.846 0 13.281 2310.058 850.64 20.5
199 00:01:19:609 1.983 0 13.281 2310.058 859.32 20.5
200 00:01:20:047 1.876 0 13.281 2315.429 889.7 20.5
201 00:01:20:390 1.892 0 13.281 2314.453 811.58 20.5
202 00:01:20:828 1.876 0 13.281 2282.226 837.62 20.5
203 00:01:21:250 1.846 0 13.281 2315.917 212.66 20.5
204 00:01:21:609 1.937 0 13.281 2301.757 108.5 20.5
205 00:01:22:047 1.922 0 13.281 2318.847 160.58 20.5
206 00:01:22:375 1.846 0 13.281 2306.152 889.7 20.5
207 00:01:22:797 1.846 0 13.281 2324.707 828.94 20.5
208 00:01:23:343 1.907 0 14.062 2306.152 881.02 20.5
209 00:01:23:562 1.831 0 14.062 2304.687 859.32 20.5
210 00:01:24:000 1.968 0 14.062 2300.292 889.7 20.5
211 00:01:24:422 1.8 0 14.062 2298.828 538.16 20.5
212 00:01:24:859 1.922 0 14.062 2318.359 885.36 20.5
213 00:01:25:203 1.937 0 14.062 2308.593 881.02 20.5
214 00:01:25:640 1.77 0 14.062 2305.175 863.66 20.5
215 00:01:26:047 1.785 0 14.062 2327.636 889.7 20.5
216 00:01:26:390 1.983 0 14.062 2297.363 737.8 20.5
217 00:01:26:828 1.907 0 14.062 2303.71 894.04 20.5
218 00:01:27:203 1.846 0 14.062 2264.16 876.68 20.5
219 00:01:27:625 1.922 0 14.062 2324.218 781.2 20.5
220 00:01:28:015 1.846 0 14.062 2265.625 859.32 20.5
221 00:01:28:390 1.907 0 14.062 2314.941 872.34 20.5
222 00:01:28:828 1.876 0 14.062 2315.917 868 20.5
223 00:01:29:218 1.815 0 14.062 2307.617 854.98 20.5
224 00:01:29:593 1.876 0 14.062 2317.382 833.28 20.5
225 00:01:30:015 1.983 0 14.062 2310.546 451.36 20.5
226 00:01:30:422 1.846 0 14.062 2290.527 785.54 20.5
227 00:01:30:890 1.892 0 14.062 2326.66 407.96 20.5
228 00:01:31:187 1.815 0 14.062 2329.101 737.8 20.5
229 00:01:31:578 1.815 0 14.062 2309.082 729.12 20.5
230 00:01:32:015 1.831 0 14.062 2303.222 134.54 20.5
231 00:01:32:406 2.014 0 14.062 2372.558 494.76 20.5
232 00:01:32:828 1.831 0 14.062 2248.046 881.02 20.5
233 00:01:33:187 1.831 0 14.062 2308.593 859.32 20.5
234 00:01:33:625 1.892 0 14.062 2301.269 876.68 20.5
235 00:01:34:031 1.831 0 14.062 2294.433 876.68 20.5
236 00:01:34:375 1.983 0 14.062 2302.246 338.52 20.5
237 00:01:34:859 1.861 0 14.062 2325.683 620.62 20.5
238 00:01:35:250 2.121 0 14.062 2312.5 841.96 20.5
239 00:01:35:609 1.968 0 14.062 2298.828 143.22 20.5
240 00:01:36:000 1.861 0 14.062 2317.382 885.36 20.5
241 00:01:36:390 1.815 0 14.062 2324.218 729.12 20.5
242 00:01:36:781 1.876 0 14.062 2336.425 321.16 20.5
243 00:01:37:234 1.907 0 14.062 2308.593 876.68 20.5
244 00:01:37:562 1.953 0 14.062 2290.039 872.34 20.5
245 00:01:38:000 1.876 0 14.843 2306.152 911.4 20.5
246 00:01:38:422 1.815 0 14.843 2301.269 902.72 20.5
247 00:01:38:859 1.876 0 14.843 2301.757 807.24 20.5
248 00:01:39:218 1.892 0 14.843 2317.871 872.34 20.5
249 00:01:39:656 1.892 0 14.843 2314.453 876.68 20.5
250 00:01:40:047 1.907 0 14.843 2264.16 898.38 20.5
251 00:01:40:406 1.876 0 14.843 2311.523 846.3 20.5
252 00:01:40:812 1.892 0 14.843 2313.476 763.84 20.5
253 00:01:41:172 1.8 0 14.843 2328.125 785.54 20.5
254 00:01:41:609 1.815 0 14.843 2294.921 499.1 20.5
255 00:01:42:031 1.876 0 14.843 2290.527 381.92 20.5
256 00:01:42:359 1.846 0 14.843 2304.687 138.88 20.5
257 00:01:42:812 1.846 0 14.843 2305.664 798.56 20.5
258 00:01:43:234 1.937 0 14.843 2307.617 863.66 20.5
259 00:01:43:578 1.876 0 14.843 2326.171 881.02 20.5
260 00:01:44:031 1.892 0 14.843 2317.871 868 20.5
261 00:01:44:437 1.907 0 14.843 2322.753 720.44 20.5
262 00:01:44:875 1.861 0 14.843 2331.054 885.36 20.5
263 00:01:45:187 1.846 0 14.843 2301.757 872.34 20.5
264 00:01:45:547 1.937 0 14.843 2335.937 681.38 20.5
265 00:01:46:000 1.922 0 14.843 2258.3 889.7 20.5
266 00:01:46:422 1.892 0 14.843 2358.886 859.32 20.5
267 00:01:46:843 1.876 0 14.843 2304.687 872.34 20.5
268 00:01:47:218 1.724 0 14.843 2311.523 885.36 20.5
269 00:01:47:640 1.724 0 14.843 2299.804 794.22 20.5
270 00:01:48:062 1.907 0 14.843 2279.296 742.14 20.5
271 00:01:48:406 1.8 0 14.843 2292.968 889.7 20.5
272 00:01:48:828 1.907 0 14.843 2290.039 859.32 20.5
273 00:01:49:187 1.922 0 14.843 2310.058 225.68 20.5
274 00:01:49:640 1.815 0 14.843 2253.906 885.36 20.5
275 00:01:50:031 1.876 0 14.843 2312.988 833.28 20.5
276 00:01:50:375 1.831 0 14.843 2319.824 868 20.5
277 00:01:50:828 1.831 0 14.843 2290.527 854.98 20.5
278 00:01:51:218 2.059 0 14.843 2332.519 872.34 20.5
279 00:01:51:672 1.831 0 14.843 2307.617 850.64 20.5
280 00:01:52:015 1.861 0 14.843 2316.894 876.68 20.5
281 00:01:52:453 1.77 0 14.843 2328.613 412.3 20.5
282 00:01:52:875 1.876 0 14.843 2362.304 225.68 20.5
283 00:01:53:218 1.846 0 14.843 2295.898 859.32 20.5
284 00:01:53:625 1.815 0 14.843 2271.484 894.04 20.5
285 00:01:54:015 1.907 0 14.843 2314.941 889.7 20.5
286 00:01:54:437 1.815 0 14.843 2310.058 859.32 20.5
287 00:01:54:843 1.876 0 14.843 2267.089 872.34 20.5
288 00:01:55:187 1.77 0 14.843 2294.433 850.64 20.5
289 00:01:55:640 1.907 0 14.843 2315.917 863.66 20.5
290 00:01:56:047 1.907 0 14.843 2306.152 854.98 20.5
291 00:01:56:390 1.754 0 14.843 2297.851 889.7 20.5
292 00:01:56:828 1.922 0 14.843 2284.667 802.9 20.5
293 00:01:57:250 1.815 0 14.843 2314.941 815.92 20.5
294 00:01:57:703 1.876 0 14.843 2311.523 763.84 20.5
295 00:01:58:015 1.831 0 14.843 2354.492 91.14 20.5
296 00:01:58:468 1.876 0 14.843 2312.988 117.18 20.5
297 00:01:58:812 1.785 0 14.843 2246.582 512.12 20.5
298 00:01:59:203 1.846 0 14.843 2281.738 772.52 20.5
299 00:01:59:672 1.831 0 14.843 2265.625 889.7 20.5
300 00:02:00:031 1.876 0 14.843 2248.535 881.02 20.5
301 00:02:00:437 1.876 0 14.843 2306.152 781.2 20.5
302 00:02:00:875 1.785 0 14.843 2304.687 872.34 20.5
303 00:02:01:218 1.861 0 14.843 2312.5 850.64 20.5
304 00:02:01:672 1.8 0 14.843 2325.195 868 20.5
305 00:02:02:062 1.922 0 14.843 2266.113 850.64 20.5
306 00:02:02:422 1.937 0 14.843 2277.343 889.7 20.5
307 00:02:02:843 2.059 0 14.843 2338.378 230.02 20.5
308 00:02:03:312 1.77 0 14.843 2306.152 65.1 20.5
309 00:02:03:625 1.876 0 14.843 2317.382 854.98 20.5
310 00:02:04:047 1.892 0 14.843 2343.261 125.86 20.5
311 00:02:04:468 1.754 0 14.843 2327.148 889.7 20.5
312 00:02:04:828 1.892 0 14.843 2328.125 850.64 20.5
313 00:02:05:234 1.907 0 14.843 2293.945 863.66 20.5
314 00:02:05:672 1.876 0 14.843 2306.152 889.7 20.5
315 00:02:06:234 1.907 0 14.843 2308.593 868 20.5
316 00:02:06:437 1.876 0 14.843 2243.652 833.28 20.5
317 00:02:06:765 1.876 0 14.843 2255.859 846.3 20.5
318 00:02:07:218 1.907 0 14.843 2253.906 828.94 20.5
319 00:02:07:640 1.831 0 14.843 2303.222 841.96 20.5
320 00:02:08:078 1.785 0 14.843 2325.683 707.42 20.5
321 00:02:08:422 1.77 0 14.062 2301.269 629.3 20.5
322 00:02:08:859 1.861 0 14.062 2322.753 234.36 20.5
323 00:02:09:265 1.876 0 14.062 2340.332 69.44 20.5
324 00:02:09:640 1.785 0 14.062 2318.359 772.52 20.5
325 00:02:10:047 1.861 0 14.062 2283.203 837.62 20.5
326 00:02:10:406 1.892 0 14.062 2270.019 147.56 20.5
327 00:02:10:843 1.77 0 14.062 2340.82 868 20.5
328 00:02:11:250 1.831 0 14.062 2258.789 798.56 20.5
329 00:02:11:593 1.77 0 14.062 2270.019 859.32 20.5
330 00:02:12:015 1.831 0 14.062 2319.824 811.58 20.5
331 00:02:12:437 1.953 0 14.062 2279.785 247.38 20.5
332 00:02:12:781 1.724 0 14.062 2296.875 121.52 20.5
333 00:02:13:265 1.892 0 14.062 2309.082 776.86 20.5
334 00:02:13:656 1.785 0 14.062 2335.449 846.3 20.5
335 00:02:14:109 1.907 0 14.062 2295.898 833.28 20.5
336 00:02:14:453 1.77 0 14.062 2294.433 651 20.5
337 00:02:14:890 1.815 0 14.062 2271.484 889.7 20.5
338 00:02:15:297 1.846 0 14.062 2280.761 881.02 20.5
339 00:02:15:609 1.785 0 14.062 2271.484 885.36 20.5
340 00:02:16:062 1.8 0 14.062 2314.941 863.66 20.5
341 00:02:16:422 1.815 0 14.062 2293.457 872.34 20.5
342 00:02:16:843 1.861 0 14.062 2315.429 885.36 20.5
343 00:02:17:265 1.892 0 14.062 2324.707 833.28 20.5
344 00:02:17:609 1.8 0 14.062 2327.148 833.28 20.5
345 00:02:18:047 1.831 0 14.062 2273.437 143.22 20.5
346 00:02:18:453 1.861 0 14.062 2292.968 78.12 20.5
347 00:02:18:812 1.861 0 14.062 2282.226 733.46 20.5
348 00:02:19:218 1.8 0 14.062 2316.894 889.7 20.5
349 00:02:19:593 1.937 0 14.062 2264.16 837.62 20.5
350 00:02:20:015 1.892 0 14.062 2314.941 876.68 20.5
351 00:02:20:453 1.815 0 14.062 2315.917 538.16 20.5
352 00:02:20:797 1.815 0 14.062 2322.265 876.68 20.5
353 00:02:21:234 1.876 0 14.062 2254.394 846.3 20.5
354 00:02:21:656 1.831 0 14.062 2310.058 199.64 20.5
355 00:02:22:078 1.8 0 14.062 2239.746 889.7 20.5
356 00:02:22:422 1.861 0 14.062 2290.039 863.66 20.5
357 00:02:22:890 1.861 0 14.062 2292.48 876.68 20.5
358 00:02:23:281 1.831 0 14.062 2301.269 868 20.5
359 00:02:23:625 1.815 0 14.062 2290.527 872.34 20.5
360 00:02:24:047 1.739 0 14.062 2292.968 863.66 20.5
361 00:02:24:484 1.663 0 14.062 2290.527 846.3 20.5
362 00:02:24:859 1.77 0 14.062 2321.289 815.92 20.5
363 00:02:25:265 1.754 0 14.062 2241.699 881.02 20.5
364 00:02:25:609 1.922 0 14.062 2304.199 820.26 20.5
365 00:02:26:047 1.831 0 14.062 2310.058 850.64 20.5
366 00:02:26:437 1.846 0 14.062 2280.761 642.32 20.5
367 00:02:26:875 1.876 0 14.062 2272.949 876.68 20.5
368 00:02:27:250 1.876 0 14.062 2333.007 221.34 20.5
369 00:02:27:656 1.892 0 13.281 2328.613 312.48 20.5
370 00:02:28:093 1.907 0 13.281 2316.894 112.84 20.5
371 00:02:28:422 1.815 0 13.281 2296.875 286.44 20.5
372 00:02:28:890 1.785 0 13.281 2302.246 633.64 20.5
373 00:02:29:218 1.861 0 13.281 2277.832 642.32 20.5
374 00:02:29:656 1.815 0 13.281 2296.875 850.64 20.5
375 00:02:30:062 1.831 0 13.281 2313.964 121.52 20.5
376 00:02:30:406 1.846 0 13.281 2299.316 603.26 20.5
377 00:02:30:843 1.754 0 13.281 2288.085 859.32 20.5
378 00:02:31:265 1.846 0 13.281 2253.906 490.42 20.5
379 00:02:31:625 1.8 0 13.281 2288.574 881.02 20.5
380 00:02:32:078 1.892 0 13.281 2316.406 876.68 20.5
381 00:02:32:468 1.861 0 13.281 2316.406 872.34 20.5
382 00:02:32:890 1.846 0 13.281 2275.878 820.26 20.5
383 00:02:33:234 1.907 0 13.281 2301.757 876.68 20.5
384 00:02:33:593 1.77 0 13.281 2203.613 881.02 20.5
385 00:02:34:047 1.8 0 13.281 2300.292 837.62 20.5
386 00:02:34:422 1.8 0 13.281 2234.863 655.34 20.5
387 00:02:34:875 1.861 0 13.281 2288.574 868 20.5
388 00:02:35:218 1.77 0 13.281 2192.871 854.98 20.5
389 00:02:35:672 1.815 0 13.281 2241.21 846.3 20.5
390 00:02:36:078 1.754 0 13.281 2274.414 833.28 20.5
391 00:02:36:453 1.754 0 13.281 2306.152 672.7 20.5
392 00:02:36:890 1.831 0 13.281 2268.554 798.56 20.5
393 00:02:37:281 1.77 0 13.281 2282.226 781.2 20.5
394 00:02:37:640 1.907 0 13.281 2288.574 820.26 20.5
395 00:02:38:047 1.861 0 13.281 2317.871 217 20.5
396 00:02:38:390 1.739 0 13.281 2316.894 833.28 20.5
397 00:02:38:828 1.8 0 13.281 2280.273 833.28 20.5
398 00:02:39:234 1.785 0 13.281 2253.417 802.9 20.5
399 00:02:39:609 1.739 0 13.281 2254.394 807.24 20.5
400 00:02:40:047 1.785 0 13.281 2298.828 52.08 20.5
401 00:02:40:437 1.693 0 13.281 2279.785 108.5 20.5
402 00:02:40:890 1.907 0 13.281 2310.058 160.58 20.5
403 00:02:41:234 1.785 0 13.281 2253.417 833.28 20.5
404 00:02:41:656 1.831 0 13.281 2307.617 881.02 20.5
405 00:02:42:093 1.739 0 13.281 2291.992 854.98 20.5
406 00:02:42:406 1.876 0 13.281 2247.558 872.34 20.5
407 00:02:42:843 1.892 0 13.281 2249.023 789.88 20.5
408 00:02:43:234 1.815 0 13.281 2273.437 841.96 20.5
409 00:02:43:656 1.846 0 13.281 2293.945 854.98 20.5
410 00:02:44:078 1.907 0 13.281 2286.621 837.62 20.5
411 00:02:44:422 1.739 0 13.281 2261.23 820.26 20.5
412 00:02:44:859 1.922 0 13.281 2263.183 221.34 20.5
413 00:02:45:265 1.815 0 13.281 2237.792 347.2 20.5
414 00:02:45:609 1.77 0 13.281 2284.667 863.66 20.5
415 00:02:46:047 1.846 0 13.281 2250.976 850.64 20.5
416 00:02:46:468 1.907 0 13.281 2247.558 251.72 20.5
417 00:02:46:906 1.953 0 13.281 2307.617 841.96 20.5
418 00:02:47:250 1.739 0 13.281 2241.21 789.88 20.5
419 00:02:47:593 1.739 0 13.281 2313.964 199.64 20.5
420 00:02:48:015 1.8 0 13.281 2304.687 108.5 20.5
421 00:02:48:437 1.77 0 13.281 2241.699 854.98 20.5
422 00:02:48:875 1.831 0 13.281 2286.132 850.64 20.5
423 00:02:49:203 1.876 0 13.281 2274.414 846.3 20.5
424 00:02:49:687 1.785 0 13.281 2307.128 716.1 20.5
425 00:02:50:078 1.815 0 13.281 2303.222 828.94 20.5
426 00:02:50:406 1.846 0 13.281 2286.132 807.24 20.5
427 00:02:50:859 2.014 0 13.281 2307.128 815.92 20.5
428 00:02:51:297 1.876 0 13.281 2262.695 112.84 20.5
429 00:02:51:703 1.815 0 13.281 2274.414 833.28 20.5
430 00:02:52:078 1.846 0 13.281 2323.73 247.38 20.5
431 00:02:52:468 1.709 0 13.281 2328.613 99.82 20.5
432 00:02:52:906 1.8 0 13.281 2286.132 802.9 20.5
433 00:02:53:281 1.8 0 13.281 2307.617 520.8 20.5
434 00:02:53:703 1.77 0 13.281 2259.765 885.36 20.5
435 00:02:54:031 1.846 0 13.281 2294.433 872.34 20.5
436 00:02:54:453 1.815 0 13.281 2271.484 889.7 20.5
437 00:02:54:890 1.922 0 13.281 2300.781 854.98 20.5
438 00:02:55:234 1.754 0 13.281 2303.222 846.3 20.5
439 00:02:55:687 1.876 0 13.281 2250.976 824.6 20.5
440 00:02:56:109 1.876 0 13.281 2247.07 833.28 20.5
441 00:02:56:453 1.77 0 13.281 2247.558 637.98 20.5
442 00:02:56:875 1.861 0 13.281 2244.14 707.42 20.5
443 00:02:57:297 1.876 0 13.281 2311.523 138.88 20.5
444 00:02:57:656 1.815 0 13.281 2299.804 190.96 20.5
445 00:02:58:078 1.8 0 13.281 2315.917 815.92 20.5
446 00:02:58:422 1.815 0 13.281 2245.117 807.24 20.5
447 00:02:58:859 1.876 0 13.281 2311.523 863.66 20.5
448 00:02:59:265 1.739 0 13.281 2277.832 828.94 20.5
449 00:02:59:609 1.846 0 13.281 2277.832 828.94 20.5
450 00:03:00:078 1.815 0 13.281 2289.062 703.08 20.5
451 00:03:00:484 1.892 0 13.281 2241.21 828.94 20.5
452 00:03:00:890 1.846 0 13.281 2327.636 703.08 20.5
453 00:03:01:265 1.8 0 13.281 2265.625 841.96 20.5
454 00:03:01:687 1.8 0 13.281 2291.015 147.56 20.5
455 00:03:02:109 1.846 0 13.281 2289.062 73.78 20.5
456 00:03:02:422 1.754 0 13.281 2247.07 73.78 20.5
457 00:03:02:890 1.815 0 13.281 2261.23 598.92 20.5
458 00:03:03:234 1.861 0 13.281 2279.785 841.96 20.5
459 00:03:03:672 1.861 0 13.281 2262.695 798.56 20.5
460 00:03:04:062 1.831 0 13.281 2295.898 850.64 20.5
461 00:03:04:422 1.831 0 13.281 2312.011 655.34 20.5
462 00:03:04:843 1.785 0 13.281 2264.16 52.08 20.5
463 00:03:05:281 1.815 0 13.281 2299.316 112.84 20.5
464 00:03:05:656 1.876 0 13.281 2279.296 56.42 20.5
465 00:03:06:062 1.892 0 13.281 2317.871 481.74 20.5
466 00:03:06:484 1.8 0 13.281 2307.128 881.02 20.5
467 00:03:12:422 1.739 0 12.5 2265.625 65.1 20.5
468 00:03:12:843 1.892 0 12.5 2312.011 73.78 20.5
469 00:03:13:281 1.693 0 11.718 2290.527 56.42 20.5
470 00:03:13:703 1.831 0 11.718 2282.226 47.74 20.5
471 00:03:14:047 1.846 0 10.937 2354.492 69.44 20.5
472 00:03:14:484 1.754 0 10.937 2277.832 73.78 20.5
473 00:03:14:906 1.8 0 10.937 2311.523 82.46 20.5
474 00:03:15:250 1.754 0 10.937 2290.527 65.1 20.5
475 00:03:15:687 1.77 0 10.937 2240.722 611.94 20.5
476 00:03:16:093 1.892 0 10.937 2302.734 117.18 20.5
477 00:03:22:890 1.815 0 10.937 2274.414 147.56 20.5
478 00:03:23:328 1.693 0 10.937 2258.3 47.74 20.5
479 00:03:23:703 1.846 0 10.937 2249.023 69.44 20.5
480 00:03:24:125 1.846 0 10.937 2259.765 151.9 20.5
481 00:03:24:531 1.77 0 10.937 2255.859 833.28 20.5
482 00:03:24:953 1.8 0 10.937 2343.75 807.24 20.5
483 00:03:25:312 1.861 0 10.937 2291.992 872.34 20.5
484 00:03:25:750 1.831 0 10.937 2266.113 820.26 20.5
485 00:03:26:172 1.77 0 10.937 2250.976 208.32 20.5
486 00:03:26:500 1.815 0 10.937 2294.921 651 20.5
487 00:03:26:922 1.846 0 10.937 2248.046 269.08 20.5
488 00:03:27:375 1.785 0 10.937 2245.117 668.36 20.5
489 00:03:27:734 1.785 0 10.937 2245.117 108.5 20.5
490 00:03:28:140 1.77 0 10.937 2271.484 859.32 20.5
491 00:03:28:515 1.8 0 10.937 2191.406 151.9 20.5
492 00:03:28:922 1.846 0 10.937 2312.5 138.88 20.5
493 00:03:29:343 1.754 0 10.937 2277.832 841.96 20.5
494 00:03:29:718 1.785 0 10.937 2274.902 230.02 20.5
495 00:03:30:125 1.77 0 10.937 2312.5 859.32 20.5
496 00:03:30:531 1.77 0 10.937 2298.828 677.04 20.5
497 00:03:30:968 1.724 0 10.937 2264.16 794.22 20.5
498 00:03:38:968 1.815 0 10.937 2355.957 52.08 20.5
499 00:03:39:328 1.831 0 10.937 2281.738 78.12 20.5
500 00:03:39:750 1.739 0 10.937 2296.875 685.72 20.5
501 00:03:40:156 1.754 0 10.937 2322.265 863.66 20.5
502 00:03:40:515 1.815 0 10.937 2303.222 859.32 20.5
503 00:03:40:922 1.785 0 10.937 2322.753 859.32 20.5
504 00:03:41:297 1.8 0 10.937 2274.414 789.88 20.5
505 00:03:41:734 1.8 0 10.937 2315.429 659.68 20.5
506 00:03:42:125 1.709 0 10.937 2198.73 125.86 20.5
507 00:03:42:515 1.709 0 10.937 2253.906 590.24 20.5
508 00:03:42:937 1.922 0 10.937 2239.257 104.16 20.5
509 00:03:43:359 1.724 0 10.937 2310.058 885.36 20.5
510 00:03:43:765 1.754 0 10.937 2261.718 859.32 20.5
511 00:03:44:109 1.831 0 10.937 2219.238 590.24 20.5
512 00:03:44:578 1.8 0 10.937 2292.968 859.32 20.5
513 00:03:44:984 1.724 0 10.937 2252.441 685.72 20.5
514 00:03:45:359 1.77 0 10.937 2246.582 247.38 20.5
515 00:03:45:734 1.785 0 10.937 2313.964 95.48 20.5
516 00:03:46:172 1.739 0 10.937 2287.109 781.2 20.5
517 00:03:46:547 1.724 0 10.937 2249.511 868 20.5
518 00:03:46:953 1.846 0 10.937 2310.058 568.54 20.5
519 00:03:47:328 1.846 0 10.937 2302.734 876.68 20.5
520 00:03:47:734 1.724 0 10.937 2246.582 828.94 20.5
521 00:03:48:140 1.739 0 10.937 2246.582 755.16 20.5
522 00:03:48:547 1.77 0 10.937 2249.511 360.22 20.5
523 00:03:48:968 1.693 0 10.937 2258.789 863.66 20.5
524 00:03:49:375 3.234 0 10.156 3943.359 581.56 6.5
525 00:03:49:812 1.403 0 5.468 2673.339 104.16 21
526 00:03:50:109 1.586 0 0.781 2818.847 13.02 22.5
527 00:03:50:515 1.754 0 0 2779.296 21.7 22.5
528 00:03:50:922 1.831 0 0 2643.066 34.72 21.5
529 00:03:51:328 1.77 0 0 2658.691 39.06 21.5
530 00:03:51:765 1.77 0 0 2537.109 43.4 21.5
531 00:03:52:109 1.709 0 0 2546.875 78.12 21
532 00:03:52:547 1.709 0 0 2484.863 47.74 21
533 00:03:52:968 1.739 0 0 2415.527 73.78 21
534 00:03:53:343 1.785 0 0 2387.207 160.58 21
535 00:03:53:781 1.831 0 0 2398.925 60.76 20.5
536 00:03:54:156 1.693 0 0.781 2418.457 125.86 21
537 00:03:54:515 1.754 0 1.562 2361.328 104.16 20.5
538 00:03:54:937 1.785 0 4.687 2323.73 91.14 20.5
539 00:03:55:312 1.77 0 8.593 2314.453 703.08 20.5
540 00:03:55:718 5.294 0 7.812 4464.843 815.92 23.5
541 00:03:56:125 1.388 0 2.343 2815.917 21.7 21.5
542 00:03:56:515 1.48 0 0 2729.98 17.36 21.5
543 00:03:56:953 5.966 0 0.781 5255.371 26.04 9
544 00:03:57:359 1.983 0 0 3748.535 802.9 33.5
545 00:03:57:797 1.358 0 0 2782.226 889.7 26.5
546 00:03:58:172 1.373 0 0 2679.687 846.3 21
547 00:03:58:578 1.403 0 0 2598.144 794.22 21.5
548 00:03:59:000 1.693 0 0.781 2539.062 112.84 21
549 00:03:59:328 1.754 0 0.781 2523.925 364.56 21
550 00:03:59:734 1.709 0 0.781 2486.816 286.44 21
551 00:04:00:140 1.617 0 0.781 2446.777 69.44 21
552 00:04:00:531 1.678 0 1.562 2373.535 52.08 21
553 00:04:00:953 1.754 0 1.562 2404.785 78.12 20.5
554 00:04:01:328 1.785 0 2.343 2321.289 78.12 20.5
555 00:04:01:734 1.754 0 2.343 2329.589 763.84 20.5
556 00:04:02:156 3.784 0 0.781 4337.402 933.1 32
557 00:04:02:593 3.875 0 0 5613.769 26.04 27.5
558 00:04:02:937 0 0 0 6078.125 30.38 25
559 00:04:03:390 4.211 0 0 6096.679 17.36 24
560 00:04:03:797 0 0 0 3420.898 17.36 33
561 00:04:04:109 1.358 0 0 2848.632 69.44 26.5
562 00:04:04:578 1.388 0 0 2721.679 846.3 21.5
563 00:04:04:906 1.51 0 0 2611.816 690.06 21.5
564 00:04:05:359 1.586 0 0 2504.882 859.32 21
565 00:04:05:781 1.663 0 2.343 2448.73 438.34 21
566 00:04:06:140 1.632 0 2.343 2397.46 802.9 21
567 00:04:06:562 1.724 0 2.343 2431.152 147.56 21
568 00:04:06:968 1.632 0 2.343 2391.601 47.74 21
569 00:04:07:375 1.678 0 3.125 2325.195 43.4 20.5
570 00:04:07:765 1.586 0 3.125 2314.453 659.68 20.5
571 00:04:08:156 1.693 0 5.468 2307.617 668.36 20.5
572 00:04:08:609 1.709 0 9.375 2306.152 347.2 20.5
573 00:04:08:922 1.754 0 11.718 2236.328 889.7 20.5
574 00:04:09:312 1.724 0 11.718 2197.265 859.32 20.5
575 00:04:09:734 1.632 0 11.718 2170.41 907.06 20.5
576 00:04:10:156 1.739 0 11.718 2267.089 898.38 20.5
577 00:04:10:562 1.709 0 11.718 2262.695 898.38 20.5
578 00:04:10:937 1.785 0 11.718 2191.894 889.7 20.5
579 00:04:11:375 1.754 0 11.718 2171.875 850.64 20.5
580 00:04:11:765 1.724 0 11.718 2222.167 876.68 20.5
581 00:04:12:140 1.724 0 11.718 2205.566 850.64 20.5
582 00:04:12:578 1.785 0 11.718 2239.746 186.62 20.5
583 00:04:12:984 1.632 0 11.718 2205.566 121.52 20.5
584 00:04:13:343 1.77 0 11.718 2289.062 95.48 20.5
585 00:04:13:750 1.678 0 11.718 2241.21 169.26 20.5
586 00:04:14:125 1.678 0 11.718 2234.863 872.34 20.5
587 00:04:14:609 1.8 0 11.718 2236.328 854.98 20.5
588 00:04:14:953 1.739 0 11.718 2238.769 898.38 20.5
589 00:04:15:375 1.724 0 11.718 2226.074 894.04 20.5
590 00:04:15:750 1.754 0 11.718 2230.957 846.3 20.5
591 00:04:16:187 1.815 0 11.718 2234.375 828.94 20.5
592 00:04:16:593 1.724 0 11.718 2246.093 217 20.5
593 00:04:16:968 1.663 0 11.718 2250.976 203.98 20.5
594 00:04:17:375 1.739 0 11.718 2281.738 56.42 20.5
595 00:04:17:797 1.693 0 11.718 2233.398 121.52 20.5
596 00:04:18:187 1.739 0 11.718 2239.746 846.3 20.5
597 00:04:18:562 1.754 0 11.718 2224.121 881.02 20.5
598 00:04:19:000 1.785 0 11.718 2214.843 881.02 20.5
599 00:04:19:437 1.739 0 11.718 2179.199 889.7 20.5
600 00:04:19:765 1.709 0 11.718 2239.746 881.02 20.5
601 00:04:20:125 1.77 0 11.718 2242.187 746.48 20.5
602 00:04:20:562 1.693 0 11.718 2253.417 763.84 20.5
603 00:04:20:968 1.693 0 11.718 2195.8 134.54 20.5
604 00:04:21:390 1.617 0 11.718 2236.328 86.8 20.5
605 00:04:21:781 1.785 0 11.718 2265.625 52.08 20.5
606 00:04:22:203 1.8 0 11.718 2240.722 225.68 20.5
607 00:04:22:609 1.617 0 11.718 2227.05 894.04 20.5
608 00:04:22:937 1.571 0 11.718 2214.843 820.26 20.5
609 00:04:23:390 1.647 0 11.718 2187.5 841.96 20.5
610 00:04:23:734 1.861 0 11.718 2246.093 143.22 20.5
611 00:04:24:187 1.632 0 11.718 2228.515 742.14 20.5
612 00:04:24:593 1.709 0 11.718 2300.781 425.32 20.5
613 00:04:24:953 1.724 0 11.718 2256.347 47.74 20.5
614 00:04:25:359 1.754 0 11.718 2197.265 65.1 20.5
615 00:04:25:781 1.785 0 11.718 2235.351 238.7 20.5
616 00:04:26:140 1.77 0 11.718 2301.757 616.28 20.5
617 00:04:26:593 1.77 0 11.718 2250.488 177.94 20.5
618 00:04:26:984 1.709 0 11.718 2242.187 811.58 20.5
619 00:04:27:437 1.586 0 11.718 2230.468 785.54 20.5
620 00:04:27:750 1.861 0 11.718 2395.019 776.86 20.5
621 00:04:28:125 1.693 0 10.156 2346.191 828.94 20.5
622 00:04:28:547 1.785 0 11.718 2445.8 39.06 21
623 00:04:28:937 1.663 0 7.812 2305.175 56.42 20.5
624 00:04:29:422 1.678 0 3.125 2342.773 47.74 20.5
625 00:04:29:765 2.349 0 3.125 2891.601 73.78 27
626 00:04:30:203 1.968 0 3.906 3030.761 125.86 28.5
627 00:04:30:593 1.831 0 3.906 2971.679 34.72 27.5
628 00:04:30:984 1.785 0 4.687 3006.347 47.74 27.5
629 00:04:31:390 1.739 0 4.687 2966.796 95.48 27
630 00:04:31:812 1.709 0 5.468 3035.156 811.58 27.5
631 00:04:32:140 1.632 0 5.468 2918.457 733.46 27
632 00:04:32:562 1.77 0 5.468 2947.265 43.4 27
633 00:04:32:953 1.77 0 5.468 2998.535 60.76 27.5
634 00:04:33:390 1.709 0 6.25 3031.25 850.64 27.5
635 00:04:33:781 1.815 0 6.25 2966.308 130.2 27
636 00:04:34:140 1.586 0 7.031 2935.546 885.36 27
637 00:04:34:562 1.373 0 5.468 2418.457 95.48 20.5
638 00:04:34:984 1.754 0 0 2403.808 30.38 21
639 00:04:35:422 1.602 0 0 2357.421 772.52 21
640 00:04:35:781 1.647 0 0.781 2440.917 911.4 21
641 00:04:36:203 1.647 0 0.781 2371.582 872.34 20.5
642 00:04:36:625 1.663 0 4.687 2410.156 724.78 21
643 00:04:36:953 1.647 0 7.031 2293.945 742.14 20.5
644 00:04:37:375 1.617 0 7.812 2278.808 854.98 20.5
645 00:04:37:765 1.663 0 7.812 2283.691 824.6 20.5
646 00:04:38:172 1.663 0 10.156 2244.628 846.3 20.5
647 00:04:38:593 1.8 0 11.718 2182.617 872.34 20.5
648 00:04:38:953 1.678 0 11.718 2287.109 911.4 20.5
649 00:04:39:375 1.647 0 11.718 2209.96 898.38 20.5
650 00:04:39:797 1.647 0 11.718 2174.316 885.36 20.5
651 00:04:40:234 1.693 0 11.718 2191.894 785.54 20.5
652 00:04:40:609 1.77 0 11.718 2204.589 885.36 20.5
653 00:04:41:031 1.785 0 11.718 2179.199 850.64 20.5
654 00:04:41:453 1.77 0 11.718 2242.187 698.74 20.5
655 00:04:41:781 1.602 0 11.718 2210.937 559.86 20.5
656 00:04:42:203 1.647 0 11.718 2182.128 108.5 20.5
657 00:04:42:547 1.724 0 11.718 2200.683 143.22 20.5
658 00:04:43:015 1.8 0 11.718 2240.722 642.32 20.5
659 00:04:43:390 1.739 0 11.718 2230.957 889.7 20.5
660 00:04:43:765 1.77 0 11.718 2254.394 850.64 20.5
661 00:04:44:172 1.617 0 11.718 2204.589 876.68 20.5
662 00:04:44:625 1.663 0 11.718 2242.675 837.62 20.5
663 00:04:44:984 1.709 0 11.718 2197.265 559.86 20.5
664 00:04:45:390 1.739 0 11.718 2258.789 859.32 20.5
665 00:04:45:812 1.77 0 11.718 2291.503 164.92 20.5
666 00:04:46:250 1.724 0 11.718 2208.984 633.64 20.5
667 00:04:46:609 1.739 0 11.718 2239.746 60.76 20.5
668 00:04:47:031 1.678 0 11.718 2311.035 607.6 25.5
669 00:04:47:453 1.8 0 11.718 2300.292 716.1 25.5
670 00:04:47:781 1.983 0 11.718 2293.457 833.28 25.5
671 00:04:48:203 1.846 0 11.718 2342.285 894.04 25.5
672 00:04:48:562 1.937 0 11.718 2323.242 868 25.5
673 00:04:49:015 1.937 0 10.937 2316.406 52.08 25.5
674 00:04:49:422 1.968 0 10.937 2364.746 47.74 25.5
675 00:04:49:797 1.907 0 10.156 2345.214 47.74 25.5
676 00:04:50:203 1.953 0 10.156 2345.214 47.74 25.5
677 00:04:50:609 1.785 0 10.156 2351.074 65.1 25.5
678 00:04:51:000 1.983 0 10.156 2384.277 82.46 25.5
679 00:04:51:437 1.983 0 10.156 2386.718 156.24 25.5
680 00:04:51:797 1.953 0 10.156 2317.871 798.56 25.5
681 00:04:52:281 1.998 0 10.156 2320.8 282.1 25.5
682 00:04:52:593 1.892 0 10.156 2326.66 69.44 25.5
683 00:04:53:031 1.907 0 10.156 2332.031 60.76 25.5
684 00:04:53:390 1.907 0 10.156 2318.847 56.42 25.5
685 00:04:53:812 1.861 0 10.156 2307.617 65.1 25.5
686 00:04:54:218 1.8 0 10.156 2303.222 703.08 25.5
687 00:04:54:609 1.922 0 10.156 2306.64 477.4 25.5
688 00:04:55:047 1.892 0 10.156 2307.617 251.72 25.5
689 00:04:55:422 1.892 0 10.156 2314.453 551.18 25.5
690 00:04:55:843 1.892 0 10.156 2299.804 160.58 25.5
691 00:04:56:218 1.953 0 10.156 2345.214 160.58 25.5
692 00:04:56:625 2.044 0 10.156 2312.988 195.3 25.5
693 00:04:57:078 1.876 0 10.156 2326.66 876.68 25.5
694 00:04:57:390 1.922 0 10.156 2318.359 802.9 25.5
695 00:04:57:797 1.998 0 10.156 2322.265 824.6 25.5
696 00:04:58:172 1.983 0 10.156 2378.417 837.62 25.5
697 00:04:58:609 1.983 0 10.156 2318.847 416.64 25.5
698 00:04:59:047 1.861 0 10.156 2258.789 112.84 25.5
699 00:04:59:390 1.892 0 10.156 2295.898 815.92 25.5
700 00:04:59:843 2.014 0 10.156 2298.828 768.18 25.5
701 00:05:00:250 2.105 0 10.156 2323.73 247.38 25.5
702 00:05:00:562 1.953 0 10.156 2364.746 260.4 25.5
703 00:05:01:000 1.968 0 10.156 2310.058 781.2 25.5
704 00:05:01:390 2.029 0 10.156 2380.859 147.56 25.5
705 00:05:01:797 1.831 0 10.156 2321.777 651 25.5
706 00:05:02:218 1.953 0 10.156 2325.195 434 25.5
707 00:05:02:593 1.968 0 10.156 2311.523 69.44 25.5
708 00:05:03:000 2.014 0 10.156 2298.828 104.16 25.5
709 00:05:03:406 1.983 0 10.156 2345.214 108.5 25.5
710 00:05:03:765 1.953 0 10.156 2317.382 156.24 25.5
711 00:05:04:187 1.907 0 10.156 2337.89 876.68 25.5
712 00:05:04:609 1.907 0 10.156 2342.285 299.46 25.5
713 00:05:05:062 1.953 0 10.156 2329.589 859.32 25.5
714 00:05:05:406 1.998 0 10.156 2305.175 837.62 25.5
715 00:05:05:750 1.846 0 10.156 2298.828 863.66 25.5
716 00:05:06:187 1.922 0 10.156 2331.054 694.4 25.5
717 00:05:06:593 1.953 0 10.156 2260.253 112.84 25.5
718 00:05:07:031 1.907 0 10.156 2307.128 473.06 25.5
719 00:05:07:375 2.014 0 10.156 2320.8 768.18 25.5
720 00:05:07:812 1.983 0 10.156 2271.484 130.2 25.5
721 00:05:08:250 1.876 0 10.156 2316.406 841.96 25.5
722 00:05:08:609 2.014 0 10.156 2345.703 177.94 25.5
723 00:05:09:015 1.998 0 10.156 2302.246 60.76 25.5
724 00:05:09:453 1.953 0 10.156 2329.101 147.56 25.5
725 00:05:09:812 1.937 0 10.156 2333.496 581.56 25.5
726 00:05:10:187 1.922 0 10.156 2320.8 841.96 25.5
727 00:05:10:656 1.876 0 10.156 2314.941 768.18 25.5
728 00:05:10:984 1.922 0 10.156 2330.566 768.18 25.5
729 00:05:11:390 1.968 0 10.156 2336.425 143.22 25.5
730 00:05:11:765 1.968 0 10.156 2338.378 99.82 25.5
731 00:05:12:187 1.846 0 10.156 2317.382 616.28 25.5
732 00:05:12:609 1.907 0 10.156 2315.917 724.78 25.5
733 00:05:13:047 1.922 0 10.156 2309.082 99.82 25.5
734 00:05:13:390 1.876 0 10.156 2367.675 585.9 25.5
735 00:05:13:828 1.831 0 10.156 2303.71 177.94 20.5
736 00:05:14:265 1.709 0 10.156 2297.363 52.08 20.5
737 00:05:14:640 1.693 0 10.156 2233.886 56.42 20.5
738 00:05:15:015 1.754 0 10.156 2194.824 47.74 20.5
739 00:05:15:359 1.617 0 10.156 2270.507 824.6 20.5
740 00:05:15:797 1.663 0 10.156 2226.562 885.36 20.5
741 00:05:16:218 1.724 0 10.156 2181.64 868 20.5
742 00:05:16:578 1.724 0 10.156 2226.074 850.64 20.5
743 00:05:17:015 1.861 0 10.156 2225.585 438.34 20.5
744 00:05:17:422 1.8 0 10.156 2252.441 833.28 20.5
745 00:05:17:781 1.739 0 10.156 2250.488 629.3 20.5
746 00:05:18:187 1.724 0 10.156 2301.269 69.44 20.5
747 00:05:18:640 1.602 0 10.156 2192.871 73.78 20.5
748 00:05:19:047 1.693 0 10.156 2212.402 846.3 20.5
749 00:05:19:406 1.724 0 10.156 2223.632 837.62 20.5
750 00:05:19:828 1.602 0 10.156 2208.007 872.34 20.5
751 00:05:20:156 1.831 0 10.156 2195.8 785.54 20.5
752 00:05:20:609 1.754 0 10.156 2250.976 607.6 20.5
753 00:05:21:015 1.77 0 10.156 2221.191 841.96 20.5
754 00:05:21:375 1.678 0 10.156 2275.878 117.18 20.5
755 00:05:21:828 1.693 0 10.156 2218.75 190.96 20.5
756 00:05:22:250 1.693 0 10.156 2236.328 837.62 20.5
757 00:05:22:609 1.861 0 10.156 2247.558 52.08 20.5
758 00:05:23:031 1.693 0 10.156 2181.64 876.68 20.5
759 00:05:23:437 1.693 0 10.156 2243.652 859.32 20.5
760 00:05:23:859 1.815 0 10.156 2232.421 833.28 20.5
761 00:05:24:203 1.8 0 10.156 2244.14 407.96 20.5
762 00:05:24:562 1.754 0 10.156 2209.96 143.22 20.5
chart by Corey S, on Flickr
25,942
5,810
That o2 sensor looks dead, should look like the picture below.
