AA7075
Chris91LX
Crystal Lake
Interesting article in my newsfeed this morning. Sounds like this aluminum alloy 7075 could be a big deal in the automotive field and others.
Nanotechnology enables engineers to weld previously un-weldable aluminum alloy
An aluminum alloy developed in the 1940s has long held promise for use in automobile manufacturing, except for one key obstacle. Although it's nearly as strong as steel and just one-third the weight, it is almost impossible to weld together using the technique commonly used to assemble body panels or engine parts.
That's because when the alloy is heated during welding, its molecular structure creates an uneven flow of its constituent elements - aluminum, zinc, magnesium and copper - which results in cracks along the weld.
Now, engineers at the UCLA Samueli School of Engineering have developed a way to weld the alloy, known as AA 7075. The solution: infusing titanium carbide nanoparticles - particles so small that they're measured in units equal to one billionth of a meter - into AA 7075 welding wires, which are used as the filler material between the pieces being joined. A paper describing the advance was published in Nature Communications.
Using the new approach, the researchers produced welded joints with a tensile strength up to 392 megapascals. (By comparison, an aluminum alloy known as AA 6061 that is widely used in aircraft and automobile parts, has a tensile strength of 186 megapascals in welded joints.) And according to the study, post-welding heat treatments, could further increase the strength of AA 7075 joints, up to 551 megapascals, which is comparable to steel.
Because it's strong but light, AA 7075 can help increase a vehicle's fuel and battery efficiency, so it's already often used to form airplane fuselages and wings, where the material is generally joined by bolts or rivets rather than welded. The alloy also has been used for products that don't require joining, such as smartphone frames and rock-climbing carabiners. [\quote]
