A/C Problem on 1999 Cadillac Deville
Primalzer
My grandpa is having a problem with his 1999 Cadillac Deville. Whenever he has the A/C going, there is a clicking coming from the dash. No air comes out of the front vents, however it will come out of all the other vents (floor and defrost) and still blows out cold from the ones that work. He took it to the local stealership and they said it would cost $600 or something dollars to fix.They said it was some motor inside the dash that they would need to tear out the entire dash to get to. Does that sound legitimate? I never really work on Caddy's or A/C systems in general, so it's all Greek to me.
4DRZ06
Reno Nv
i had problems like that on a 92 deville and the dash had to be ripped a psrt to fix, it sounds legit to me
and on a 99 deville i had the blower motor went out (vert common) and it was like 300 to fix.
Sprayin
Public Enemy #1
Chicago, IL
when a caddy has problems expect to pay ridic $$ to get it fixed. Not just labor, but parts are ridic also.
SRT41320
Lake in the Hills - IL
its prolly the blend door system (controls which vents get air) is it only a problem with a/c? if it doesnt matter heat or a/c then its the blend door system. if its just a/c then its got to be something to do with the "auto temp control" system
P
Primalzer
Yeah, it won't blow out of the front vents regardless of heat or A/C. The dealer said it was the "mode door" failing to open to the front vents, therefore needing to be replaced. I had a feeling if the whole dash had to be ripped out to get at the problem, then $500-$600 is probably about right.
bikrboy128
Some say.....
Wheaton
sounds about right to me. i just did something similar to a ford exploder a week ago. :ford:
SRT41320
you might not have to pull the dash...take a look under it and see if you can see the blend door mechanism....is it electronic controlled or cable? (digital temp display and buttons - or - levers and knobs)
P
Primalzer
Its a digital controlled unit, so i would assume it would have to be electronic. I'll take a look under there tomorrow morning, and see what I can find.
