🔧 BUILD 8f8 - build summary
denmah
Oct 26, 2020
44
329
1995 SN95 ford mustang
goal, go in the 8 second range for in the 8000 dollar range.
95 mustang rolling chassis
4.8 - riverdale speed springs, sloppy stage two, summit stage two, PCM4less 232.232 cam (used all three for testing in build)
marketplace th400 with trans brake, jakes custom budget steel converter
twin wally 450 pumps in fuel cell that came with the car
stock gen4 truck intake, Warr performance throtttle, FASSTER performance fuel rails, PQY regulator
stock iron manifolds hotside with monkey fab flanges and gate provisions
twin VS racing 44 mm gates
VSracing S475 turbo
vs racing dented 4 inch intercooler
Snake eater 1000-1500 bosch 210's tested in car all worked great
4bar 18 dollar ACdelco map sensor
terminator x ecu
car made 750whp and went 8.80s at 153mph
will update with more info!
ArmyBimmer
Oct 28, 2020
28
91
Coming in at the tail end of the build is awfully satisfying.
First post: Goal, 8s.
Also first post: Time slip, 8.858
What you didnt see was the 6 motors worth of R&D that it took to get there... It was a very long and painful process to watch as it happened, but rewarding. Glad I went along for the ride via youtube, it was well worth it!
