Hola El sloppos,
Checking in with my twin turbo OEM small block ford build. (hold your boos!) Coming from building a SFWD Mazda that was in the process of building to be an 8 second moms wagon into a 89LX Coupe. posted some deets in the mazda HERE in my intro thread.
Owned an 89 vert in the past and foxes have just always been my favorite car ?‍ . Learned a shit ton from the sloppy following that applied to the mazda on its build and still have a shit ton of sloppy recommended parts swapping over into the mustang.
Anyways, on with the tom foolery. Skip to my "Master plans" if you don't car about the way it sits at the moment
My goal is to make it out to rocky Mt. race week with the car in the next two years alongside my cousin and co-owner of our business that is building a LS 6.0 Swapped Nissan 240sx
Car
Florida Car
1989 Mustang Coupe SSP
Just picked it up a few weeks ago and the pr. owner showed me the transport receipt from July when he had rolled it off the transport from FL. It shows, thing is super clean! A dime to have here up in MA.
Engine
(there was no paperwork, going based off what pr. owner relayed. I bought this car for the chassis basically, running and driving was a plus)
331 Scat Stroker kit in an OEM SBF block
9:5.1 Pitons
AFR 185 Cylinder heads
Comp Roller Rockers (unsure of springs)
Anderson N41 Cam
Upgraded Radiator
Upgrded Deep Oil pan
usual upgraded fluid dampr pully etc.
BBK Longtubes and unknown axle dumps
ECU/Electronics
EFI Source MS3 GoldBox
normal run of the mil autometer tach on the dash
innovative wideband and gauge
oil temp gauge and oil pressure
stock 160 cluster sti;ll using all stock controls
Chassis/Drivetrain/Suspension
UPK Tubular front with upper and lower CA's
QA1 Front Coils and Caster/Camber plates
Subframe connectors
UPR Rear Upper and lower Arms
Later year C4 trans with B&M 3 speed forward shifter (claims to have a PA rebuild) it does have an upgraded PA pan. Unknown Stall converter
Stock 8.8 rear with 3.73 gears
stock rear drums and axles. Stock front hubs
Power Adder
Zex Wet Dry kit. Plumbed and wired. Claimed to "never had been used" ill take that with a grain of salt lol
MASTER PLANS before 2021 Season Leave everything the way it is, just add some spoolie bois ?
Changes/Winter plans
Yank and refresh
Sloppy machine check, sloppy hones, new rings, crank bearings, main bearing gaskets, yadda yadda
Might get a little fancy and step up to AFR205 heads
Strange 35 spline 5 lug, spool and 4.10 gears
Front Stoptech upgrade to 5 Lug
8.5 10pt cage (made in house)
Jegs Kirky Clone race seat
Self built TQ box supports (made in house)
LS1 Up and forward headers, chop LS flanges off and swap SBF hi port flanges on
Vband inlets aimed into the fenders (made in house)
Mirror Viren Singh Racing 67/62 .81ar turbos
2 in/1 out inercooler or A2W IC with ice box (Made in house)
All charge piping and exhaust will be made in house. (unsure about exhaust routing so far)
Strip the entire car and give it some Por15 Love
Rebuild the trans
I have a massive amount of stuff coming over from the mazda to include, Lowdoller Motorsports sensors (Map sensor, Oil temp/pressure, Coolant temp/pressure, IAT sensor, etc) Also have a ton of material, charge piping, parts and accessories from monkeyfab, Chromoly tubing, Chute mount supplies, gauges etc.
Yes its an OEM bottom end, yes it's going to hatch, yes its going to be glorious. i bought it for the chassis, having fun with the SBF is just a plus. Hope to find a good deal on a dart block or LS in the future when the fireworks of rods happen. If you wanna follow along ill be updating the thread and my youtube channel under Dirty Water Racing
Ill jump on my phone and dump some photos shortly
Car
Florida Car
Engine
9:5.1 Pitons
Anderson N41 Cam
Upgraded Radiator
ECU/Electronics
Subframe connectors
Power Adder
Yank and refresh
Rebuild the trans
