It’s that damn magical 10 speed. My car gets like 13mpg and only time it’s ever seen 20 was 100% stock on the highway.
this past weekend's trip was 19.2 across 1145 miles... which included at least 2 hours of dicking around moving my boat around.
fuck man 11K miles already ?
Here ya go. When I get mine back, I have to install this. Otherwise launches will be horrendous.truck is pretty consistent basically at this point with 13.7-13.8's.
my only better 60' was 1.97 seconds... this is 2.00. i just dont know how i can leave harder... if you try to brake torque the truck basically just shuts the fuck off.
GM Truck stabilitrak disabler
This is a plug and play harness to disable stabilitrak with the flip of a switch. Has been tested on 14-18 1/2 ton trucks and 15-20 3/4-1 Ton Trucks Lead times are 1-3 weeks on orders.www.tuningbyshanehinds.com
Hmmm, probably not. Seems like a fail safe in the tune, torque management setting.this will even fix what the truck does if foots on gas and brake?
like i couldn't do a brake torque burnout if someone had a gun to my head.
if you give it any brake and any gas, it keeps RPM's below like 1200 and then won't let you mash the gas for 2-3 seconds.
Press traction control button to turn off TC. The press and hold until stabilitrak says disabled. It'll help with the launch. The disabled I posted is needed, because Stabilitrak re-engages after 30-35mph. Very lame
Ah oki knew how to turn it off fully i just dont know if i have tried to launch like that
i know when i went to the track, flooring the truck from a stop, there is a major delay.
it's like the truck does not know what to do
This is gonna sound dumb as fuck... but I wonder if the Pedal Commander would help with that?
I say this because it's a piggyback, not an actual tune. So no tampering with that and warranty voiding
TC off and 2WD mode does nice burnouts in my 18
