5.7 vortec
Ricky Gonzalez
Hey everyone. Been gone for a while but need help. I'm at work and working on a 2002 GMC W4500. the issue is it doesn't want to start on it's own. If started with starting fluid it runs great. So far the other mechanic and I have changed:
Fuel pump
Fuel filter
Fuel pressure regulator
Plugs
Wires
Dizzy cap and rotor
MAP sensor
TPS
IAC valve
Losing patience and time as I need this truck 100% for a job at O'hare. Any advice would be appreciated.
Mike K
Forum Sponsor
Have you confirmed fuel pressure at the rail?
EmersonHart13
John
Don't these things have injector issues? Being leaky or something?
Ricky Gonzalez
Ricky Gonzalez
Yes they do. Got it all figured out. Ended up having to replace the fuel spider in the manifold. Horribly clogged injectors. Thanks for the input
