Keep up the good work. I have an EP 4T80e going into a Fiero with a turbo L67 and hope that it holds up. I've been keeping a close eye on this thread and I'm excited to see what you come up with.
honestly street tire, I don't think you go through a 4t80e. especially a fresh one with some of EP's mods inside (quicker shifts and more pressure).
Even with small slicks you probably couldn't hurt it. Right now I have the 3.11 gears and 29.5" slicks and ridiculous amount of torque and that really loads the transmission hard.
I wouldn't even worry...
So we did some more work. Took out the 4t80e trans from my car to make the adjustment for the trans/motor bracket in order to be able to do the in car transmission work. So we took this last 4t80e apart.
That one went neutral in 3rd then got stuck in 3rd gear. Next day it looked normal. Could burnout in 2nd-3rd gear (without glue). Took the pan off and it was FULL of clutch material.
Surprised to see only 3rd clutch pack is destroyed (the worst of all the 4t80e i have hurt)...
This trans did 1st gear starts and shifted very slow and sluggish, especially 2-3. 2nd gear always has a few leopard spots but nothing bad.
This trans was 100% stock low miles 2008 4t80e.
So there is pretty solid evidence that the Forward clutches, coast clutch and forward sprag take a beating mostly when doing 2nd gear take off on glue at very high boost. Something the 4t65e-HD doesn't have a problem with surprisingly (size for size of course).
This trans had PERFECT forward clutches and perfect coast clutch.
What I will try first is taking out the reverse clutch pack and piston to save weight in that critical reverse drum. The one that stops and has to spin again going into 3rd gear. Also will do a in depth shift kit.
I'm still digging at the diagrams that I have which are incomplete.
James if you read this, please scan the 4t80e power flow and hydraulic flow chart in color (the ones where you see hydraulic fluid path in each gear). That would save me some time. I'd love to complete this tomorrow.
I want to drill out forward clutch feed,coast clutch feed, 3rd clutch feed and 2nd clutch feed as well as improve grip on the 4th band to assist in engine braking and possibly helping the sprag not take all the load even getting in and out of throttle during 2nd gear burnouts.
