fuck
i have a crapload of high res pics of most of the main info.
how do we do this shit for posterity?
coast clutch is "assisting" holding the forward sprag under acceleration, it is disengauged when at coast, and reengages.
its one of the issues with the pedaling of a burnout and one reason i suggest a full coast lockup all the time with some sort of external solenoid that wont release it till the brake pedal is pressed. this should keep the relativly weak forward sprag from taking as much abuse.
Remember i dont have a position leverthe only range not applying coast is D4 (aka OD)
D,2,L all use it. D not until third gear for towing/hauling and engine braking.
the forward sprag is holding in all except 4th, but the clutches dont assist untill D3 or lower
you sure your looking at the two frictions from the coast clutch or the more numerous plates of the forward clutch? the forward and coast clutches are concentric pistons, from the look of it,
apply passages are adjacent in the drum center bushing, so wear could factor into cross talk and partial apply/draging
but since the forward sprag is likly to get damaged during burnouts/shock loadings, we cant expect it to handle peak tq after the rollers develop hot spots or end up with divots in the ramps that prevent proper wedging (why it was suggested oversize rollers be installed).
but maybe with some work, somewhere there's an adjacent passage that can apply the coast clutch or just an external solenoid to force the coast to hold the sprag stationary and keep it from dying....then at least we can find the next weak link.
by its design as a MPG device allowing the wheels to overrun the engine rpm it spends alot of time freewheeling which is the roller/ramps forte'.... dogbone sprags dont like to freewheel without eventual flat spotting of the heels.
if we're looking at the sprag not holding (look at the rollers/ramps, i found the wear on the two ive torn down) as being an issue, certainly easier to deal with permanent engine braking or external solenoid activation than trying to ge tthe sprag to hold via an upgrade or brand new parts.
via the mechanical drive charts, that forward sprag is holding quite a bit of Tq as its holding the ring gear on the input in all gears except 4th where it overruns.
so its dealing with full engine Tq plus the Tq multiplication of the tq converter, plus the leverage of 1st (and less leverage with 2nd)
that little fucker is carrying more load than you realize and abuse isnt helping it do its job.
weld it solid and delete 4th was the only other suggestion i got. id rather have a solenoid triggered coast apply so i can at least manually control it and maintain streetability.
case passage access for rev and coast circuits look to be fairly easy at the drivers rear lower corner where they go through the driven sprocket support
