4L60E / Yank 3200 SS
ADDING THIS BACK IN TO THE MIX
I bought the car in Sept 2002 with 37,642 miles
The maintenance records are as follows:
Trans service ( drop the pan, replace filter and gasket ) 37,815 Sept 19 2002
Trans service ( drained twice ) 43, 859 October 11 2003
Trans service 52,961 February 19th 2005
Trans service 56,799 November 12 2005
YANK 3200 SS installed, so 3-4 quarts of new fluid installed with it, 57,470 April 1 2006
Trans service 66,928 Sept 4, 2011
Mileage when it was dropped off: 75,237. I worked at a dealer from 2002-2006 so that's why the services were frequent.
The upper automatic console section and the shifter will be available as well but I will list those separately once they are off of the car.
The trans will be located in Pingree Grove IL ( unless someone wants to meet me @ Speed Inc in Schaumburg ).
There is a B&M 24K cooler that will go along with it as well.
Shifts perfect, fluid is cherry red, THERE IS NO SHIFT KIT OR OTHER MODIFICATIONS TO THE TRANSMISSION
I do not know what these things go for... The converter has to be worth a decent buck. I did/do not floor the car when in 4th gear. The car has about 10-12 1/4 mile passes on it dating back to 2006.
Has not seen more than Sunday cruising since
I am not sure what applications this transmission can be used for... I assume other RWD GM vehicles / trucks or LS swapped RWD vehicles.
$650 OBO
I am not interested in shipping
Pictures to follow once removed from the car
Reactions: Bob Kazamakis
Bob Kazamakis
I’m the f-ing lizard king
85,566
45,820
Joel
900 over 10 years ago... I mean is someone really going to spend 1K or 1500 on a used Fbody trans ?
Hey, if someone wants it for 1200 bucks let me know !!
I’m stating it’s a good deal. Not many are going to necessarily want a 4l60 but they’re out there.
Reactions: Gav'sPurpleZ
EmersonHart13
54,261
22,477
Your still selling this? I thought things went south and you were keeping it?
Reactions: Shawn1112
