Double check your s*** and make sure that the scale is in the proper area.
I had to adjust the gray teflon strip knockoff unit in the Turbo Regal way back when dinosaurs roamed the earth
Recently a fellow member caused me to remember this s*** and that it would leave you underfilled using the 4L60E marks..
To that end.
Double check your shit
It is not to scale but that's what happens when you are using grubby callused fingers drawing on Android version Ms paint
The zero point is the bottom of the case counterbore before it radiuses and necks down for the O-ring seals on the aftermarket style dipstick.
You would measure from the face that sits up against that surface.
Keep in mind the knockoff that we got required me to grind the case of that casting lip around the counterbore....
As well as having the radius the side of the fitting that goes towards the case so that it would sit down all the way against that surface.
Brian's lokar unit didn't require any modification to its body.
To that end.
