item flagged... what was it?
i call bs on your bs sir, aftermaraket cams are available for the 60v6 with DIS. I HAVE ONE. and now as a matter of fact, comp cams are doing cams. the rest is true though
Are you sure? Comp Cams only has 3 cams for 60* V-6's. http://www.compcams.com/DefaultWide.asp
The 240, the 252, and the 260. All of them are non-DIS.
Also Eagle, Isky, Crane (when they were around), Schneider, Elgin, PAW, Melling, Edelbrock, Lunati, and Wolf all make cams for 60* V-6's but not a single one is compatable with DIS.
Intense Racing and ARI sell re-grinds, But these are factory camshafts re-ground to slightly different spec's. Not really an aftermarket cam. The re-grinds are more for folks who want to use forced induction on their 3X00 engines.
milzy has a few....new cores
http://www.milzymotorsports.com/
ya sure they arent compatible with DIS? remember they still use a dizzy gear to drive the oil pump driveshaft....and i dont think the cam snout has changed from the old 2.8/3.2 dizzy motors and the later DIS one's
