I am too, thats why I want to get another in the couple years, it seemed to have improved drasticallyI am genuinely blown away how easy this was to set up and get rolling.
Where are you located?Thoughts on what to sell my other fdm printer at? Or where lol?
I figure fb is the easiest, but idk if I have the mental fortitude to try to sell there.
Prusa mini+ with a few spools.
Technically the piece that holds the pinda sensor is broken but I printed a replacement and just never put it on cause it was still printing correctly.
New pre assembled is like 450 with a month lead time. I was thinking 300 with the spools included.
I'm in the West Chicago/Carol stream/Wheaton area.Where are you located?
Very nice!Just going ham on the miniatures
The 2 of the same are a side by side of the fdm vs resin
View attachment 142982View attachment 142987View attachment 142985View attachment 142980View attachment 142981View attachment 142984View attachment 142986View attachment 142983
Glad we could help each other out lolVery nice!
Really loving the prusa mini. Been a work horse last couple days.
I am having some problems want an opinion or three. I have been trying to use my Sovol SV04 with PLA and it just doesn't seem to work. I've got the printer set up in an enclosure, I've printed PLA with it before (I thought, it's been a while I typically lean ABS) and I've been having a problem where it just suddenly stops extruding. The extruder seems to have tons of "grab" (see below) and I've even had a fucking pretzel of PLA inside my extruder. I've changed the nozzle and replaced the PTFE in the extruder with Capricorn (the old stuff looked fine, but since I do ABS why not) as well at this point to no avail and tried 3 PLAs, 2 Hatchbox and one Sovol one of the PLAs was even new white PLA. I'm going to throw some esun PLA+ in to see what happens, then try ABS that failing. This is driving me fucking batty, maybe I should try opening the enclosure up to reduce the overall internal temperature? I can tell you the fans don't seem to impress me, it's a direct driven extruder and the cooling parts seem different than say the MK6 stuff I typically use on my SV01.
Heat creepI am having some problems want an opinion or three. I have been trying to use my Sovol SV04 with PLA and it just doesn't seem to work. I've got the printer set up in an enclosure, I've printed PLA with it before (I thought, it's been a while I typically lean ABS) and I've been having a problem where it just suddenly stops extruding. The extruder seems to have tons of "grab" (see below) and I've even had a fucking pretzel of PLA inside my extruder. I've changed the nozzle and replaced the PTFE in the extruder with Capricorn (the old stuff looked fine, but since I do ABS why not) as well at this point to no avail and tried 3 PLAs, 2 Hatchbox and one Sovol one of the PLAs was even new white PLA. I'm going to throw some esun PLA+ in to see what happens, then try ABS that failing. This is driving me fucking batty, maybe I should try opening the enclosure up to reduce the overall internal temperature? I can tell you the fans don't seem to impress me, it's a direct driven extruder and the cooling parts seem different than say the MK6 stuff I typically use on my SV01.
