đź’¬ OT 3D printers...who has one?
Mr_Roboto
25,917
31,094
Neither, it's the power. My sovol was giving me a headache so I was using this heap of shit instead :rofl:
I timed it once and it gave a heating error at 5 minutes. I'm thinking that there's probably something in the code. It's just not coming up to temp quickly. If I start dicking with the PID numbers if I increase the Proportional control it should make it more aggressive. From what I remember about the derivative system it could cause under shoot if it's too aggressive so I may reduce that some.
Mr_Roboto
25,917
31,094
I did the learn, it doesn't seem to help. Ever manually hack them?
Also, I owe you guys a pic or two but I took care of the Melzi board there. Desoldered the connector and soldered the wires right on to the pads. I'm sure it's fire code compliant. :rofl:
Any of you guys do a Creality 4.X board? The big thing I'm wondering about is the throughput still shit when using Octoprint or is the Pi->board connectivity faster? They seem to be a decent blend of improved capacity and price and it'd be a drop in for my Sovol. I'd love the Duet but man it's hard for me to spend over half the cost of my printer on a controller board. Oddly if the Melzi in the other printer goes it'd be more likely to get the Duet if I can get this one sorted just because I'd probably need to rewire anyways to stuff anything in.
Lord Tin Foilhat
60,728
56,890
Privy Chamber
I'd go SKR mini over creality boards
Mr_Roboto
25,917
31,094
debating on sending it.
Mr_Roboto
25,917
31,094
I put the SKR board in yesterday. Not a bad install on the Sovol, the later ones have 2 X axis ports. They must use a different motor on an Ender3 for the Extruder though because I had to flip my wires around so that it ran the correct direction. I also don't have my filament switch nor the under chassis fan hooked up. I guess that's next. Although it definitely needs a calibration it heats up without puking out. Not sure wtf is up with my Creality Board. After I pulled it out I got it to flash a bootloader without any drama either which is also kind of annoying since I'd have probably gone that route. Doesn't really matter though I have a little printer that probably needs a board or I'll swap the Melzi out on my Tronxy instead. I've gotta get Marlin 2.0 to build first though, I'm having some problems with it at the moment.
The motors are insanely quiet compared to the stock board, it's nice. There's a bunch of new features too I need to poke around with as well.
Also something strange is I didn't see any way to set the stepper current on the SKR board.
32,644
16,111
On the SKR bored if might be in UART or SPI mode for your drivers.... you will end up setting stepper current via the Marlin firmware via m code settings
For stuff like homing you can do individual overrides that will allow you to run at 30% of stepper current to prevent you from crashing hard. You will also be able to set motor idle percentage per axis, individually if you want
Mr_Roboto
25,917
31,094
Hell I may end up going that way.
This is fucking driving me crazy. I'm still having warm up issues with the hot end. So far I have:
-A new 30W cartridge
-new temperature sensor
-new board
-stock heat break, block
I am monitoring my PSU via my hooked in Simpson 260 and I'm not seeing any fluctuation of voltage I'd consider significant. I changed the shroud at a point to a 3D printed one, is it possible it's just too fucking efficient and the heater can't maintain temperature? It was temperamental even stock but I'm really wondering if this made it significantly worse. It seems like the biggest problem is just raw warm up time, it eventually gets there but not altogether quickly. One thing I will confess to having not done is take a basic thermometer of some kind and trying to measure the temperature of the hot end as it's warming up to make sure the calibration matches up. That said the cold temperature seems to be spot on and matches with the bed sensor.
Mr_Roboto
25,917
31,094
It was glued in still when I changed to the SKR board. Now then is it right on the SKR Board? I think so, I mean the temperature goes up in Octoprint and on the display, it just takes it 5+ minutes to get up to full temp which the printer doesn't seem to like. I realize thermal protection is there for a reason but my god it seems to be causing some annoying situations.
