3D printers...who has one?
Posts
27,872
problem is that they would all need "bodywork" to sand out the layers/sqezeout
something like that would be good for resin printers
Lord Tin Foilhat
Lord Tin Foilhat
Posts
50,013
Riding the Hubble
Yeah it would need a final sand/spray or acetone smoothing to get the layered look gone
zenriddles
The Swamp won. :-(
Posts
4,400
Holiday Inn
I've got a sandblasting setup. What about a sanding followed by a walnut shell blasting or some mild media like that?
These things really would need to hold up to life on a truck wheel, so would need to be made out of some fairly robust material.
Bob Hope
Formerly Alive
Posts
75,209
He’s saying sanding....with sand paper. Not media blasting. Sanding them smooth and painting them would hold up the best.
I don’t see center caps as a high wear item. Most are made of plastic anyways.
zenriddles
The Swamp won. :-(
Posts
4,400
Holiday Inn
I knew what he meant. I worded my sentence poorly.
After a CONVENTIONAL SANDPAPER SANDING to best appearance reasonably possible, after the conventional sanding, would there be any benefit to a mild media blasting?
Lord Tin Foilhat
Lord Tin Foilhat
Posts
50,013
Riding the Hubble
On way to know is to try. Not much info out there in that regards
zenriddles
The Swamp won. :-(
Posts
4,400
Holiday Inn
I would be willing to put up for materials to see what the results would be. Don't care about the inside appearance, outside must be smooth and silver with black center.
Posts
27,872
id say some media tumbling with the vibratory units some water/lubricant and suitable media would polish it up
but id say sand and use high build primer with a few hand sanding with a couple topcoats would do just fine
Mr_Roboto
Posts
15,618
Joliet
Yeah I don't see it as a big deal to make in all probability.
Any idea why I am getting high spots like this? it is driving me nuts since I think it is causing layer shift.
Also first prints on the TronXY. Just some basic pla and a quick disconnect for my Dillon.
Mr_Roboto
Posts
15,618
Joliet
I'm going to redo my heated chamber to add the Tronxy then I think I'm going to swap to PLA and low infill and take a shot at this. The goal is to convert it into aluminum. I have about 6 hours of CAD time into it, so we'll see if it's viable or not. If you notice I didn't do anything with the latching part because I was getting lazy about the idea of having to add cores to this.
Mr_Roboto
Posts
15,618
Joliet
sw 17. I like 07 better so far there doesn't seem to be a ton more this does that's remarkable so far and it's lots busier.
I dabbled in FreeCAD and it wasn't great. I just signed up for a fusion 360 acct I need to try. I have done Inventor in the past as well and it was definitely okay.
Bob Hope
Formerly Alive
Posts
75,209
360 is where it’s at. It’s also nice to be saved to your account so you can access from multiple machines.
Mr_Roboto
Posts
15,618
Joliet
The new limits kind of suck unless you are paying from what I understand. I need to make some alterations to downloaded stuff so it is worth a shot.
SW is great it took me 5ish hours to make both pieces including me redoing the top 3 times :rofl:
Bob Hope
Formerly Alive
Posts
75,209
I haven’t noticed anything missing when modeling on a personal free account.
Mr_Roboto
Posts
15,618
Joliet
I was having trouble with weird quirks on Linux. Maybe that was my issue.
Also, looking good here on the test fit. Top printing now.
Mr_Roboto
Posts
15,618
Joliet
Oh dear God that's brilliant I cannot find a steady rest for my leblond Regal
How big of a lathe? I was talking to someone else on another forum and they were just thinking about printing one 100% and giving it a shot. I'm thinking I like the comfort of aluminum personally but If you're ballsy. I can't decide if the failure mode of it would be catastrophic or not if it happened...............
Posts
27,872
15x40 but it'll swing over 16.
I'd have to figure that thing would be pretty f****** strong. Only thing you could do to make it any more homogeneous would be post-treatment or enabling ironing between layers.
All of the steady rest forces basically upward and towards the rear of the machine I don't think you're going to have a problem if anything it might move a little bit but you should be able to compensate.
It's better than not having a steady rest or using a rigged up set up with two by fours
Mr_Roboto
Posts
15,618
Joliet
I was more concerned with having a piece of stock whipping around if it broke. I mean hell, I'm thinking if you believe it'd work going totally the hell ghetto and making some ABS fingers or something. :rofl:
I do have a fuckload of cam followers in the basement though, now that you've said it (or I have whichever.)
