Well, got this biatch going. Finally. I don't have a display yet and one of the temp sensors isn't working (suspect I need to specify the bed sensor in the calibration) but I do have Marlin 1.1 on my Melzi board instead of Repetier .91 which doesn't have melt down protection. A few helpful hints along the way:
-Avoid the TinyUSB programmers like the plague. They're designed for small sized AVRs and therefore they don't work with even a lower capacity board like this Melzi. I will say the cable was useful. I have 2 now but I think there's components here that can be salvaged for a microprocessor project so I'm not altogether concerned.
-What did work was taking an Arduino Uno and making it into a programmer which is available via the sample sketches. I had the cable from the programmers which I was able to directly connect afterwards.
-The GUI errored out initially because of it not recognizing my printer board as a valid Arduino.
-I had to copy, paste and modify the command from the Arduino GUI to put the boot loader on the board. I ran it in the Windows Command Prompt with the -F flag. I had to go into the Ardunio directory to run the command its self, delete out the path that was explicitly listed for execution and add double quotes ("") around the path of the file I was flashing to it as the boot loader.
-After the boot loader was on the Melzi board it was simply a matter of plugging it in via USB, building code then flashing it up.
