3800 Series 1 random stalling
b4black
before black
Jun 6, 2008
1,331
542
Oswego
I'm hoping you all can help with a random stalling issue on a 1992 Series 1 3800 (L27). Yesterday the car stalled four times . It restarted each time.
The last time I was driving:
  • Cruising about 45 mph, straight, no bumps in the road.
  • It just stopped running - no chugging, no surging, just died.
  • I had a fuel pressure gauge hooked up. Pressure was fine before and after the stall (~45 psi).
  • Had a vacuum gauge hooked up - looked fine until the stall
  • 16 in Hg of vacuum at idle. All hoses look good. Sprayed carb cleaner all over - no changes in RPM.
  • 1992 engine does not use EGR.
  • Catalytic converter is not plugged
  • Wiggled key & ignition switch, seems OK.
  • Recent plugs, wires and upgrade to Type 2 coils/module (used from L67 motor)
  • Connected a scan tool. TPS, O2, MAF all look OK.
I fear I have a dreaded "intermittent electrical issue". :picard: Hopefully someone has some suggestions. Thanks.
  • b4black
  • 3
  • 366
