I thought I had a post about this here but I couldn't find it. So...
It's a fucking minivan!
And it was rusty as fuck too!
I decided it do the deed anyway, because it was free, and I ain't scared of no rust anymore.
Fuck hood prop rods, not in my fleet!
Rear disc brakes!
2005 GTO parts for the street cred
Lots of details here that I didn't really explain. Power steering reservior is TIG welded aluminum from some kind of sign post thing and other random scrap. Lots of massaging hoses and wires and stuff, though 90% is bolt-on W-body pieces. MAP sensor is mounted via 3D print to the drivers side dogbone, lots of other 3D printed hose mounts and things like that as well. Modified a W-body L67 fuel pump assembly (cut some plastic off it) and it drops right into the U-van tank. All new nylon fuel lines and NiCu brake lines, and some upgrades to the power wires and a dedicated audio system power block for the 3D printed adaptation of a bluray player and (still working on) 1080p screen.
Sound deadening +1. 35% coverage using butyl strategically, with a decoupled dense material layer on the floor (it's a budget build so factory fiber dense material on door panels and other trim). It's not like this vehicle had a noise problem to begin with, just want to reduce the few problem areas as much as I could without going overboard...
Also, because 3800's sound so amazing with anything that isn't dead silent exhaust:
Plan is to run true dual with the X-pipe muffler. We'll see how that sounds (not going for loud at all, surprisingly difficult to find a quiet stainless muffler), it might need a helmholtz tube to mitigate drone and something like the pretzel in my 97 LeSabre, but I'll get to that eventually.
Rear disc brakes!
